    • RB Brake System Upgrade Kit (380/365) for Tesla Model S/X Front & Rear (P/N 2466-K & 2435-K). Select Option if you have 1-piston rear calipers (Mando).
  • FRONT
  • Front OEM
  • 2435- Rear RB
  • RB Brake System Upgrade Kit (380/365) for Tesla Model S/X Front & Rear (P/N 2466-K & 2435-K). Select Option if you have 1-piston rear calipers (Mando). RB Brake System Upgrade Kit (380/365) for Tesla Model S/X Front & Rear (P/N 2466-K & 2435-K). Select Option if you have 1-piston rear calipers (Mando). FRONT Front OEM 2435- Rear RB
    MSRP: $6,650.00
    Now: $6,320.00
    (You save $330.00 )
    TES-IRP-01
    The rear caliper upgrade kit is for Model S/X 2016 and earlier models (w/separate parking brake) only & is not compatible with 2017+ "Mando" Single Piston Calipers With Integrated Parking Brake. Although, you will get RB's 2pc light-weight rotor upgrade.
    • 2 ea Front 2 pc light weight big rotors (380x32mm)
    • 2 ea Front 6 pot heavy duty calipers
    • 2 ea Front caliper adaptors
    • 2 ea Rear 2 pc light weight stock size rotors (365x28mm)
    • 2 ea Rear 4 pot calipers (Not applicable for those with 1-piston Mando integrated parking brake)
    • 2 ea Rear caliper adaptors (Not applicable for those with 1-piston Mando integrated parking brake)
    • 1 car set brake lines
    • 1 car set brake pads
    • All neccessary hardware kit
    • Front: PD1666 (RB6M3 caliper)
    • Rear: PD968 (RB4M2 caliper)
    • Rear: PD1929 (for 1-piston caliper)
    Replacement rotor ring:
    • Front: D501-01
    • Rear: D406-01
    • Front: 2466-K
    • Rear: 2435-K
    OTOR WT. COMPARISON (LBS)
    FRONT
    (355mm vs 380mm)
    REAR
    (365mm)
    TOTAL/SIDE TOTAL/CAR
    OE 1PC
    28.2 22.5 50.7 101.4
    RB 2PC
    22.5 17.3 39.8 79.6
    WT. SAVING 5.7 5.2 10.9 21.8(21.5%)
    • RB BBK (380/365) for Tesla Model 3 Front+Rear (P/N 2605-K & 2633-K) Rear
      MSRP: $6,260.00
      Now: $5,950.00
    • Typical brake kit Front rotor
      RB Calipers Brake System Kit (380/380mm) for Ferrari models 348/355 (300/310mm) Upgrade Front & Rear (P/N 2362-K & 2363-K)
      MSRP: $8,900.00
      Now: $8,455.00
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
      MSRP: $8,400.00
      Now: $7,980.00
    • RB 2 pc Rotor Kit (380/365) for Tesla Plaid Stock Replacement Front & Rear (P/N 2679 & 2435) RB 2 pc Rotor Kit (380/365) for Tesla Plaid Stock Replacement Front & Rear (P/N 2679 & 2435)
      MSRP: $2,900.00
      Now: $2,755.00
