    • Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K)
  • front rotor wt
  • rear rotor wt
  • front pad
  • rear pad
  • Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) front rotor wt rear rotor wt front pad rear pad Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K)
    MSRP: $17,850.00
    Now: $16,960.00
    (You save $890.00 )
    (1 review) Write a Review
    RCCB-TES-X420.410
      • 2 ea. Front 6-piston caliper (6061-T6 forged aluminum alloy)
      • 2 ea. Front CCM rotor
      • 2 ea. Front caliper adaptor
      • 2 ea. Rear CCM rotor
      • 2 ea. Rear caliper bracket (Reuse OE caliper)
      • 1 car set brake pads for CCM rotor
      • 1 set of stainless steel braided brake line
    • Front: PD1395-360
    • Rear: PD1929-360
    • 2R44-K
    • Requires 21" wheels with some trim on dust shield edges for larger rotors.
    Weight reduction:
    OE IRON 28.2 22.5 50.7 101.4
    RB CCM BBK
    18.4 14.4 32.8 65.6
    WT. SAVING 9.8 8.1 17.9 35.8(35.3%)
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    Avoid:
    Forum discussion:
    • 5
      For Tesla model X LR
      Posted by Yen-Feng Lee on Dec 3rd 2023
      I put these monsters into my lovely model X LR. I order them Gloss black, that matches the rear stock calipers. After the run in procedure, I found them much more smooth, when you push them really hard. Excellent break that matches the Model X needs.
    • Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • Carbon Ceramic Brake System Kit (390/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K)
      MSRP: $36,000.00
      Now: $34,200.00
      MSRP: $8,400.00
      Now: $7,980.00
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
    • Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K) Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K)
      MSRP: $6,950.00
      Now: $6,599.00
