    • RB Brake System Kit (380x34/380x30) Direct Replacement for Porsche 991 GT3, 981 GT4
  • Front kit
  • Front rotor wt
  • Rear kit
  • Rear rotor wt
  • RB Brake System Kit (380x34/380x30) Direct Replacement for Porsche 991 GT3, 981 GT4 Front kit Front rotor wt Rear kit Rear rotor wt
    MSRP: $9,000.00
    Now: $8,550.00
    (You save $450.00 )
    POR-991-irp-380.380
    This brake kit is developed specifically to replace the OE brake kit that comes with standard brake (Red calipers & Iron rotors) or with pccb to downsize to 380 rotor kit to run smaller wheels & tires.
    • 2 ea front track duty 6 pot calipers (RB6M2 Direct mt. use no adaptors)
    • 2 ea front 380x34mm iron rotors
    • 2 ea rear track duty 4 pot calipers (RB4M2/RB4M3 w/adaptors)
    • 2 ea rear 380x30mm iron rotors
    • 1 set rear caliper adaptors
    • 1 car set SS braided brake lines
    • 1 car set street pads (track pads are optional adder)
    Feature & benefit:
    • Run 19" wheels (or some 18" aftermarket wheels) - Check wheel fitment below
    • Lower cost and easy to find brakes pads (Standard FMSI: Front=Mustang GT500, Rear=GTR)
    • Rotors are fully compatible with standard brake rotors so you can swap to OE rotors if needed
    • Calipers are made for a direct swap with 991 Red calipers with 225mm mt spread
    • Calipers are made for track duty with open top for easy pad change
    • Caliper finish option including hard anodized for a never fade surface finish
    • Kit comes with all the needed components for a 100% bolt on installation
    • Guarantee to outperform OE Brembo or AP Racing kits or your money back
    Replacement Rotor rings:
    • Front: D501-04
    • Rear: D501-07
    • Front: PD1666
    • Rear: PD968
    • Front 2421-K
    • Rear 2422-K
    Click here for more caliper details:
    • Front caliper
    • Rear caliper
    Reference AP/Essex pricing (Excluding pads):
    • Front: 394x34mm $7,000
    • Rear: 380x32mm $5,900
    • front kit 380mm w/6 pot rear kit 380mm w/4 pot kit
      MSRP: $16,100.00
      Now: $15,300.00
    • RB 2 Pc Rotor Kit (380/380) for Porsche 991 GT3 & 981 Cayman GT4 (Stock Replacement) PN: 2421/2422 Front 2421
      MSRP: $3,840.00
      Now: $3,648.00
    • 8 ea SS Pistons for Porsche 991 GT3, 991 Turbo, 991 Turbo S & 981 GT4 Rear Calipers
      MSRP: $280.00
      Now: $266.00
    • Boots and Seals Kit - Porsche 991 GT3, 991 Turbo, 991 Turbo S & 981 GT4 Rear Caliper (Price is for 2 Calipers) Boots and Seals Kit - Porsche 991 GT3, 991 Turbo, 991 Turbo S & 981 GT4 Rear Caliper (Price is for 2 Calipers)
