    • RB CCB Rotor Kit (380x34/380x30) for Lexus ISF Retrofit Upgrade Conversion to CCB, Front & Rear (P/N 2C41 & 2C36) or (2R48 & 2C36) Priced for 2 front rotors Only.
  • TE front caliper
  • caliper wt
  • front kit
  • front kit - 3d
  • RB CCB Rotor Kit (380x34/380x30) for Lexus ISF Retrofit Upgrade Conversion to CCB, Front & Rear (P/N 2C41 & 2C36) or (2R48 & 2C36) Priced for 2 front rotors Only. TE front caliper caliper wt front kit front kit - 3d
    MSRP: $6,800.00
    Now: $6,450.00
    (You save $350.00 )
    LX-CRK-ISF
    Available from:
    Figs Engineering
    This kit is specially made for ISF model upgrading to CCB brake kit:
    Installation requires RCF Track Editions calipers or RB calipers.
    Kit contents:
    • 2 ea front CCB rotors (380x34mm)
    • Rear ccb brake kit (380x30mm) - Optional
    • 1 set front ccb street pads
    Replacement discs:
    • Front: CR10
    • Rear: CR27
    • Front: PD_RCF-360 (If RCF TE calipers)
    • Front: PD1666-360 (If RB 6 pot calipers)
    • Rear: PD968-360
    • Front: 2C41-K
    • Rear: 2R48-K
    Available from Figs Engineering
    • RB CCB Rotor Kit (380x34/380x30) for Lexus GS/GSF/RCF Models Retrofit Upgrade Conversion to CCB, Front & Rear (P/N 2C27 & 2C36) Note: Priced for 2 front rotors Only - Add  Rear Kit option for 4 corners.
      MSRP: $6,630.00
      Now: $6,300.00
      MSRP: $10,500.00
      Now: $9,975.00
    • rotor kit front rotor
      RB-CCB Rotor Kit (380x34) for Ford Mustang GT550 2015+, V8 Perf., Mach 1 (2021+) Front Upgrade CCB Conversion from Stock Iron Rotors
      MSRP: $6,820.00
      Now: $6,479.00
      MSRP: $14,348.41
      Now: $13,630.00
      MSRP: $10,500.00
      Now: $9,975.00
