Quick view [PD1868/PD1469] Front & rear Iron Rotor Street Pads - BMW M Performance package (2018+) MSRP: Was: Now: $0.00 Choose Options Compare Quick view [PD2155_75/PD2059-391] Brake Pads for Iron Rotors - BMW M3/M4 G82/83 (21+); M5 F90 (2018+); M8 (2020+) for CCB to Iron Conversion Front & Rear MSRP: $632.00 Was: Now: $598.85 Choose Options Compare Quick view RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) MSRP: $3,320.00 Was: Now: $3,155.00 Choose Options Compare Quick view RB-CCB Rotor kit (394/380) for BMW F90 M5/M6/M8 CCB Conversion Upgrade from Iron (PN: 2R26 & 2R27) MSRP: $12,925.00 Was: Now: $12,278.00 Choose Options Compare Quick view RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27) MSRP: $13,500.00 Was: Now: $12,825.00 Pre-Order Now Compare Quick view Save 10% on RB 2pc Rotor Kit (390x36/380x28) for BMW M5 F90 Stock Replacement (P/N 2644 & 2645) MSRP: $2,950.00 Was: Now: $2,802.50 Choose Options Compare Quick view [PD1868/PD1469] Front & rear Iron Rotor Street Pads - BMW M Performance package (2018+) Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation Highly durable M Performance 2018+ BB44=BV-42 (40/44x33.5) 32mm ht supplied BB11 MSRP: Was: Now: $0.00 Choose Options Compare Quick view [PD2155_75/PD2059-391] Brake Pads for Iron Rotors - BMW M3/M4 G82/83 (21+); M5 F90 (2018+); M8 (2020+) for CCB to Iron Conversion Front & Rear The front pads have been modified to 75mm depth to better fit the iron rotor rings (vs. 87mm for ccb rotors) Fit the following calipers: Front Caliper: Rear Caliper: MSRP: $632.00 Was: Now: $598.85 Choose Options Compare Quick view RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) Installation note: Rotor kits are made for ccb to iron rotor downgrade conversion with a 100% "bolt on installation" w/o modifications. Kit contents: 2 ea. Front 2 pc rotors (400x38mm) 2 ea. Rear 2 pc rotors (380x28mm) 1 set brake pads... MSRP: $3,320.00 Was: Now: $3,155.00 Choose Options Compare Quick view RB-CCB Rotor kit (394/380) for BMW F90 M5/M6/M8 CCB Conversion Upgrade from Iron (PN: 2R26 & 2R27) This CCB rotor kit is designed and made for M5/M6 F90 iron rotor to ccb conversion upgrade. 100% direct bolt-on installation. No modification RB discs are made of long carbon fibers stronger and more durable than OE ccb rotors' chopped carbon fibers... MSRP: $12,925.00 Was: Now: $12,278.00 Choose Options Compare Quick view RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27) This CCB rotor kit is designed and made for M5/M6 F90 iron rotor to ccb conversion upgrade. 100% direct bolt-on installation requires no modifications. RB discs are made of long carbon fibers stronger and more durable than OE ccb rotors' chopped carbon... MSRP: $13,500.00 Was: Now: $12,825.00 Pre-Order Now Compare Quick view Save 10% on RB 2pc Rotor Kit (390x36/380x28) for BMW M5 F90 Stock Replacement (P/N 2644 & 2645) Kit includes: 2 ea Front 2 pc rotors 390*x36mm (vs. OE 395x36mm). 2 ea Rear 2 pc rotors 380x28mm Brake pads (optional) *Actual pad contact rotor diameter is only 390mm, so our 390mm rotor can eliminate undesirable rusty lip developed after... MSRP: $2,950.00 Was: Now: $2,802.50 Choose Options Compare Compare Selected × OK
