    • RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description
  • RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description
    MSRP: $7,920.00
    Now: $7,524.00
    (You save $396.00 )
    FOR-IRP-380.380
    This racing brake kit is specially made for track racing so that you can possibly run on 18" aftermarket wheels (download wheel fitment to verify), as a result the rear rotor hat can no longer accomondate the OE drum brake (ID=227mm) which must be deleted in order to install the kit.
    By purchasing this kit you agree to have read above disclaimer and acknowledge that you would assume the full responsibility of the rear drum brake deletion.
    Brake pads included in the kit is for street driving, for off-street applications please use the links below.
    Rear: PD1395
    Rear: PD1001
    Brake pad Selection Guide
    Replacement disk:
    • Front: D602-03
      Rear: D603-05
    Wheel fitment diagram:
    • Front: 2611-K
    • Rear: 2612-K
    • RB 2pc Rotor Kit (380/380) for Ford Mustang Shelby GT350 2016+ Downsized from stock for Track Racing (delete rear drum brake) (P/N 2611 & 2612) Front OEM
      MSRP: $3,025.00
      Now: $2,873.75
    • RB-CCB System Kit (380/380) 6/4 Pot Calipers for Ford GT, Mustang GT350 (PN 2C69 & 2C17) - Fits 18" Wheels (vs. OE 19") for Low Cost Wheels/Tires - Custom built for Track Racing Only - Must Delete Rear Emergency Drum Brakes. RB-CCB System Kit (380/380) 6/4 Pot Calipers for Ford GT, Mustang GT350 (PN 2C69 & 2C17) - Fits 18" Wheels (vs. OE 19") for Low Cost Wheels/Tires - Custom built for Track Racing Only - Must Delete Rear Emergency Drum Brakes.
      MSRP: $16,000.00
      Now: $15,200.00
    • RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98) RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98)
      MSRP: $11,891.06
      Now: $11,296.51
    • RB 4 Piston Caliper (170x43) for Ford Mustang GT350 Rear (2 calipers)
      MSRP: $2,060.00
      Now: $1,960.00
    • RB Bracket & Caliper Kit for Ford Explorer ST Perf. Rear BBK (380 vs. OE 355mm) RB Bracket & Caliper Kit for Ford Explorer ST Perf. Rear BBK (380 vs. OE 355mm)
      MSRP: $550.00
      Now: $522.50
