    • RB 2pc Rotor Kit (420/370) for Audi C8 (2019+) RS6/7, RSQ8, Bentley Continental GT V8 Stock Replacement; or CCB Downgrade Conversion (P/N 2687 & 2585)
  • Front RB rotor
  • Front OE rotor
  • rear
  • Front rotor dimensions
  • Rear rotor dimensions
  • Front OE caliper
  • RB 2pc Rotor Kit (420/370) for Audi C8 (2019+) RS6/7, RSQ8, Bentley Continental GT V8 Stock Replacement; or CCB Downgrade Conversion (P/N 2687 & 2585) Front RB rotor Front OE rotor rear RB 2pc Rotor Kit (420/370) for Audi C8 (2019+) RS6/7, RSQ8, Bentley Continental GT V8 Stock Replacement; or CCB Downgrade Conversion (P/N 2687 & 2585) Front rotor dimensions Rear rotor dimensions Front OE caliper
    MSRP: $3,880.00
    Now: $3,492.00
    (You save $388.00 )
    AU-IRK-C8-RS7
    • 2 ea front two piece rotors (420x38mm vs. OE 420x40mm)
    • 2 ea rear two piece rotors (370x28mm vs. OE 370x30mm)
    • 1 set street pads (Optional)
    • 1 set front 6 pot calipers (Brembo for C7/RS7 rebuilt and newly powder coated in red by RB) including street pads & caliper adaptors - Optional
    • 1 set rear RB 5 pot fixed pistons ePB calipers replacing OE 1-pot floating calipers including adaptors & street pads for a bolt on installation - Optional
    • This rotor kit is developed for a direct swap to your bulky and heavy stock iron rotors.
    • Also for original ccb rotors (440/370mm) downsize conversion to (420/370) iron rotors - Optional.
    • Front rotor rings: D604-01
    • Rear rotor rings: D502-09
    • Front/Rear: PD1899.PD1895
    Forum discussion: Front 10 pot calipers replacement.
    Advantage of Brembo 6 pot vs. OE/Akebono 10 pot:
    Yes for those discriminating C8 owners w/10 pot, or C7/C8 owners looking to replace/upgrade to 6 pot BBK.
    This is a "Customized" Standard Audi brake kit for you.
    • Calipers: OE/Brembo 6 pot (BA-61) or RB 6 Pot (RB6XL1) w/open top
    • Pads: OE/Aftermarket (FMSI#D1530)
    • Rotors: Standard Audi stock size 400 or 420mm
    • Caliper Adaptors: RB
    Features:
    • Substantial unsprung weight reduction (29%).
    • Proven result on C7.
    • Fewer components.
    • Components* are easy to source at lower cost.
    • Professionally built.
    • Overall performance improvement.
    *Brembo piston sizes are standard vs. Akebono's non-standard (w/decimal).
    • RB 2pc Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB to Iron Conversion (P/N 2584 & 2585) Front rotor
      Now: $4,056.50
    • RB 2pc Rotor Kit (400/370) for Audi C7 (12-18) RS6/7 CCB to Iron Conversion (P/N 2574 & 2585) Front wt.
      MSRP: $3,650.00
      Now: $3,460.00
    • RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10)
      MSRP: $13,500.00
      Now: $12,825.00
    • [PD1899.PD1895-391] RB Bundle Street Pads for Audi C8 RS6/7, RSQ8,  Bentley Continental GT V8 Front & Rear w/Iron Rotors OE
      Now: $475.00
      MSRP: $14,348.41
      Now: $13,630.00
