    • RB 2pc Rotors (380x34) for Ford Explorer ST Front Retrofit to Jeep SRT8 2012+ (WK2) 6 Pot Calipers (Not Included in Price)
  • RB BBK (380x32) Wt: 23.13 lbs
  • OE 362x32 Wt: 29.50
  • RB 2pc Rotors (380x34) for Ford Explorer ST Front Retrofit to Jeep SRT8 2012+ (WK2) 6 Pot Calipers (Not Included in Price) RB BBK (380x32) Wt: 23.13 lbs RB 2pc Rotors (380x34) for Ford Explorer ST Front Retrofit to Jeep SRT8 2012+ (WK2) 6 Pot Calipers (Not Included in Price) RB 2pc Rotors (380x34) for Ford Explorer ST Front Retrofit to Jeep SRT8 2012+ (WK2) 6 Pot Calipers (Not Included in Price) OE 362x32 Wt: 29.50
    MSRP: $1,630.00
    Now: $1,550.00
    (You save $80.00 )
    2666-K
    Kit Content:
    • 2 ea Lightweight 2 pc high performance rotors (380x34 vs. OE 362x32mm)
    • 1 set of WK2 caliper mounting hardware
    • Brake pads (Optional)
    Note: Brake pads are optional.
    This retrofit rotor kit is exclusively made by RB and allows Explorer ST (2020+) owners (Base or sports models) to upgrade your front brake (floating calipers) to Jeep SRT8 WK2 (2012+) 6 pot caliper w/380x34mm rotor.
    Required Modifications:
    (Alternatively consider this RB6 pot caliper kit for a no modification installation)
    1. Due to SRT8 Brembo calipers have wider body than stock floating calipers, depending on your wheel configuration you may need to add a 3mm wheel spacer for stock 19" wheels to clear the caliper axially, if you have larger wheels or other aftermarket 19" you may not need it.
    2. Banjo bolt connection retrofit procedures:
    This is how OE brake lines look like (left=position hook removed, right=before removal)
    A. Remove OE banjo (90 deg) position hook (to be like above pic on left w/o hook)
    B. Remove WK2 caliper banjo position block (flange) - Same idea as Explorer's hook to secure the banjo bolt from rotation but in reality they are not required.
    Hatch lines is where the block (flange) is removed
    90 deg hook removal is not hard you can use a hacksaw and a file or hand grinder.  Removing WK2 flange is a little bit harder but can be done with a hacksaw or hand grinder. After this retrofit you will notice the connection is neater and easier to secure and detach (banjo bolt) as necessary.
    If you ever have to revert back to OE floating calipers, it will be just like WK2 (as retrofitted) w/o the hook and it will function just as well w/o any concern of losing this engagement flange which is redundant and NOT needed based on our experience.
    • Jeep SRT8 WK2 6-pot calipers are required (not included in the price) which must be acquired by customer.
    • Rotors are made for a direct bolt-on installation to Explorer spindle.
    Fixed pistons caliper requires more axial space on outboard than OE floating calipers but it should fit Stock 20" or larger wheels w/o issue or you may need to add wheel spacers as needed to clear the spokes.
    Design is confirmed by fitment test:
    OE Caliper with pads:
    WK2 OE Caliper w/pads:
    You can purchase them from Jeep/Dodge dealers (68146610/11AA (Right/Left)-$734.40+$55 for core/ea) Or Search eBay for used calipers for about 1/2 of the price ($380):
    Contact us if you need assistance in finding the correct calipers.
    Replacement rotor rings: D501-04
    Replacement brake pads: PD1291
      Caliper Caliper Wt Rotor (mm) RB Kit Rotor Wt (lbs) Total Wt Saving
    ST/Original Dual (Floating) 21.7 362x32 29.5 (OE 1pc)
    Jeep WK2 6 pot (Fixed) 16.4 380x34 23.1 (RB 2pc)
    Wt Saving   5.3/Caliper   6.4/rotor 11.7/Side
              23.4/Axle
    • RB 2pc Rotors (400x34) for Ford Explorer ST Front Retrofit to Jeep Trackhawk 6 pot Calipers (Not Included) RB 2pc Rotors (400x34) for Ford Explorer ST Front Retrofit to Jeep Trackhawk 6 pot Calipers (Not Included)
      MSRP: $1,750.00
      Now: $1,662.50
    • RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front
      MSRP: $4,026.00
      Now: $3,824.70
    • RB 6 Pot Caliper BBK (400x34mm) for Ford Explorer ST (2020+) Front Caliper color option
      MSRP: $4,466.00
      Now: $4,242.70
    • RB 2pc Rotor Kit (390x34) for Jeep WK1 Retrofit to Hellcat 6 pot Caliper for A 100% Direct Bolt On Installation - Front RB 2pc Rotor Kit (390x34) for Jeep WK1 Retrofit to Hellcat 6 pot Caliper for A 100% Direct Bolt On Installation - Front
      MSRP: $1,573.00
      Now: $1,494.35
    • RB 4 Pot Caliper Brake Kit (360x32mm) for Ford Explorer ST (2020+) Front RB 4 Pot Caliper Brake Kit (360x32mm) for Ford Explorer ST (2020+) Front
      MSRP: $3,080.00
      Now: $2,926.00
