        • CROSS OVER TUBE
        • MIS FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
        • CROSS OVER TUBE
        • MIS FITTINGS
    • RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
  • RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front
    MSRP: $4,026.00
    Now: $3,824.70
    (You save $201.30 )
    2667-K
    Kit Content:
    • 2 ea RB 6 pot calipers
    • 2 ea Light weight high performance rotors
    • 1 set of caliper adaptors and mounting hardware
    • 1 set brake pads
    • 1 set stainless steel braided brake line
    Feature and benefit:
    • Replacing OE bulky and heavy cast iron calipers.
    • Fixed pistons for a quick brake response than OE floating pistons.
    • Easy brake pads exchange and maintenance.
    OE Calipers (loaded with pads):
    OE Red Caliper (w/pads)
    RB Calipers (w/pads)
    Weight comparison (Lbs):
      Caliper/ea (w/pads) Rotor/ea Total
    OE 1pc Kit (362x32) 21.7 (Dual pistons) 29.5 (1pc)
    RB 2pc Kit (380x32) 13 (6 Pot) 22.5 (2pc) estd.
    Wt Saving 8.7 7.0 15.7/side (31.4/axle)
    Replacement rotor rings:D501-01
    Replacement brake pads:PD1666
    Wheel fitment template: 2667-K
    • RB 6 Pot Caliper BBK (400x34mm) for Ford Explorer ST (2020+) Front Caliper color option
      MSRP: $4,466.00
      Now: $4,242.70
    • RB 4 Pot Caliper Brake Kit (360x32mm) for Ford Explorer ST (2020+) Front RB 4 Pot Caliper Brake Kit (360x32mm) for Ford Explorer ST (2020+) Front
      MSRP: $3,080.00
      Now: $2,926.00
    • RB 2pc Rotors (400x34) for Ford Explorer ST Front Retrofit to Jeep Trackhawk 6 pot Calipers (Not Included) RB 2pc Rotors (400x34) for Ford Explorer ST Front Retrofit to Jeep Trackhawk 6 pot Calipers (Not Included)
      MSRP: $1,750.00
      Now: $1,662.50
    • RB 6 Pot Caliper BBK (410x34) for Toyota Tundra 2022+ FRONT RB 6 Pot Caliper BBK (410x34) for Toyota Tundra 2022+ FRONT
      MSRP: $4,600.00
      Now: $4,370.00
    • RB 2pc Rotors (380x34) for Ford Explorer ST Front Retrofit to Jeep SRT8 2012+ (WK2) 6 Pot Calipers (Not Included in Price) RB BBK (380x32) Wt: 23.13 lbs
      MSRP: $1,630.00
      Now: $1,550.00
