Quick view Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) MSRP: $305.00 Was: Now: $289.75 Add to Cart Compare Quick view RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 MSRP: $271.70 Was: Now: $258.12 Add to Cart Compare Quick view RB 2 pc Rotor Kit (330x28) for Stoptech, Alcon/Prodrive BBK Rotor Repl. for Subaru WRX, Audi etc. (Price is for 2 rotors) MSRP: $1,094.50 Was: Now: $1,039.78 Add to Cart Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front MSRP: $2,490.00 Was: Now: $2,365.00 Compare Quick view RB BBK (328x28) for Subaru WRX/BRZ; Toyota GT86; Scion FR-S Front MSRP: $2,600.00 Was: Now: $2,470.00 Choose Options Compare Quick view RB Caliper Brake Kit w/Stock Size (294x24) 2 pc Rotors for Scion FRS, Subaru BRZ & WRX Front MSRP: $2,350.00 Was: Now: $2,232.50 Choose Options Compare Quick view Save 10% on RB BBK (328/330) Bundle Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) MSRP: $4,620.00 Was: Now: $4,389.00 Compare Quick view Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) MSRP: $2,800.00 Was: Now: $2,650.00 Choose Options Compare Quick view Caliper Brackets - For Subaru Rear BBK Upgrade to Legacy 2.5GT w/316x18 mm Rotors - Price per pair (x2) This bracket allows you to upgrade your Subaru rear rotors to Legacy 2.5GT 316x18 mm rotors. Replacement Rotors for this brake kit: P/N: 9160-01 MSRP: $305.00 Was: Now: $289.75 Add to Cart Compare Quick view RB 1pc rotor kit (290x10mm) w/170mm drum - Subaru Rear 09-13 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Rotor wt: 10.7 lbs MSRP: $271.70 Was: Now: $258.12 Add to Cart Compare Quick view RB 2 pc Rotor Kit (330x28) for Stoptech, Alcon/Prodrive BBK Rotor Repl. for Subaru WRX, Audi etc. (Price is for 2 rotors) These surface-mount two piece rotors are made for replacement rotors for Alcon/Prodrive BBK for Subaru WRX. You must purchase the complete rotor assembly from us first before you can puchase the replacement rotor rings. RB rotor rings have the same 10... MSRP: $1,094.50 Was: Now: $1,039.78 Add to Cart Compare Quick view RB BBK (322x25) for Subaru BRZ, Scion FR-S, GT86 Front This Brake Kit Is Obsolete & Superseded by P/N 2567-K (332x28mm)! If you purchased this BBK (322x25mm) in early 2000 and are looking for replacement rotor rings, be advised they are no longer available, instead you should puchase a new rotor assembly... MSRP: $2,490.00 Was: Now: $2,365.00 Compare Quick view RB BBK (328x28) for Subaru WRX/BRZ; Toyota GT86; Scion FR-S Front Kit includes: 2 ea 4 pot calipers 2 ea caliper adaptors 2 ea 2 pc rotors (332x28mm)* 1 set brake pads (Optional) *This rotor assembly + caliper spacers can be used as a replacement for the original 322x25mm rotors which has been obsolete... MSRP: $2,600.00 Was: Now: $2,470.00 Choose Options Compare Quick view RB Caliper Brake Kit w/Stock Size (294x24) 2 pc Rotors for Scion FRS, Subaru BRZ & WRX Front Feature & benefits: An affordable high performance brake kit that has been highly regarded for its value and durability in Subaru WRX community since early 2000. Brake kit is made to replace stock calipers and/or stock rotors Kit comes with RB light... MSRP: $2,350.00 Was: Now: $2,232.50 Choose Options Compare Quick view Save 10% on RB BBK (328/330) Bundle Kit for Subaru WRX (2008+)/BRZ; Toyota GT86; Scion FR-S Front & Rear (P/N 2567-K & 2315-K) Kit includes: 2 ea front 4 pot calipers 2 ea lightweight 2 pc rotors (332x28mm) 2 ea rear 2 pot calipers 2 ea lightweight 2 pc rotors (330x22mm) - 100% compatible with OE rear drum brake 1 car set brake pads 1 set SS brake lines Replacement rotor... MSRP: $4,620.00 Was: Now: $4,389.00 Compare Quick view Save 10% on RB BBK/OE Caliper kit (322/316) for Subaru BRZ, Scion FR-S, GT86 (2014-K & 2060-K) Replacement components Brake pads: Front: PD647 Rear: PD770 Front rotor rings: D214-01 Rear 1pc: 9160-141 MSRP: $2,800.00 Was: Now: $2,650.00 Choose Options Compare Compare Selected × OK
