Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) MSRP: $16,500.00 Was: Now: $15,675.00 Choose Options Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) Kit contents: 2 ea. Front Z28 6-piston calipers 2 ea. Rear Z28 4-piston calipers 2 ea. Front CCM rotors - OE Brembo (Option RB long carbon fibers) 2 ea. Rear CCM rotors - OE Brembo (Optional RB long carbon fibers) 1 car set street pads 1 car set brake... MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) Kit includes: 2 ea light wt composite hats. 20 sets hardware kits OE Stainless Steel Hat:RB Composite Hat: MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor built with RB long (continuous) carbon fibers 2 ea. Rear CCM rotor built with RB long (continuous) carbon fibers 1 car set caliper adaptors & hardware 1 car set... MSRP: $16,500.00 Was: Now: $15,675.00 Choose Options Compare Compare Selected × OK
