    • RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K)
  • RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K) RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K)
    MSRP: $6,138.00
    Now: $5,831.10
    (You save $306.90 )
    TY-IRP-01
    This BBK is specially designed for Supra MK5 enthusiasts seeking for the best value of their brake upgrade:
    Front RB Caliper Kit:
    • 2 ea RB6M Track duty calipers
    • 2 ea Caliper adaptors & mounting bolts (pre-assebled)
    • 2 ea 380x34mm center mount light weight rotors
    • 1 set of street performance pads (PD1666)
    D501-04
    Rear OE Caliper Kit - Retain the use of OE calipers & its parking brake functionality
    • 2 ea Caliper bracket (integrated 1pc) for oversize rotors.
    • 2 ea 370x24mm center mount light weight rotors
    • 1 set of street performance pads (PD2220)
    D404-06
    Wheel fitment template: Only need to check on front BBK, if the front kit clears the rear should be no problem.
    2657-K:
    Compare to other smilar kits:
    Brembo front kit:
    • $4,595 - $8,995
    • 6 piston monoblock calipers
      380mm 2 pcs rotors
      Complete Front Axle Set.
    Endless Racing MONO6 Inch-Up Brake Kit - 2020+ Toyota Supra (A90)
    • $11,250.00 USD
    • Front: 370x34
    • Rear: 355x24
    Endless Mono Rally brake kit for the A90 Supra $35,300.00 $34,999.00
    • Mono 6 Rally Front with 400x36mm 2-Piece CMC rotors
    • Rear Inch Up Kit with 355x24mm 2-Piece CMC rotors [Compatible with the Electronic Parking Brake]
    • The kit can be run on the street, but it's definitely the most extreme kit that Endless currently has available.
    AP Racing Brake Kits for the Toyota GR Supra!
    Front: 372/380x36 Rear: 360x30 (Eliminates Parking Brake)
    $8,498 - $9,189
      • CP9660/372mm Radi-CAL Front Competition Kit, $4399.00
      • CP9668/372mm Radi-CAL Front Competition Kit, $4799.00
      • CP9450/365mm Radi-CAL Rear Compeition Kit, $4099.00
      • CP9562/380mm Radi-CAL Front Road Kit, $4399.00
    • RB 6/4 Pot Caliper  Kit (380X34/365X28) for C7 Corvette (P/N 2370-K & 2375-K)
      MSRP: $7,178.60
      Now: $6,819.67
      MSRP: $8,400.00
      Now: $7,980.00
    • RB 6/4 Pot Caliper Kit (380x34/380x28) for BMW M3 E90 (P/N 2478-K & 2399-K)
      MSRP: $7,700.00
      Now: $7,315.00
    • RB BBK Rotor Kit (390/355) for Viper G3-G5 Retrofit to ACR-E 6 Pot CCB Front Caliper; Re-use Rear OE Calipers (P/N 2497-K & 2219-K)
      MSRP: $5,050.00
      Now: $4,795.00
    • RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077) RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077)
      MSRP: $3,540.00
      Now: $3,360.00
