    • Save 10% on Rebuild Kit for for Tesla Plaid & LR Front Calipers (Price is for 2 Calipers)
  • Gap between OE boots=69.38 (max rotor & pad clearance)
  • Gap between RB boots=69.56
  • Gap between RB pistons (No movement)=67.69 (Max rotor & pad clearance= -1.69mm less than OE)
  • Gap between OE pistons (free)
  • Gap between OE pistons (compressed) - below boots
  • OE piston & boots extended=43.28
  • RB piston & boots extended=41.77 (Extension=+1.5mm vs. OE)
  • Save 10% on Rebuild Kit for for Tesla Plaid & LR Front Calipers (Price is for 2 Calipers) Gap between OE boots=69.38 (max rotor & pad clearance) Gap between RB boots=69.56 Gap between RB pistons (No movement)=67.69 (Max rotor & pad clearance= -1.69mm less than OE) Gap between OE pistons (free) Gap between OE pistons (compressed) - below boots OE piston & boots extended=43.28 RB piston & boots extended=41.77 (Extension=+1.5mm vs. OE)
    (You save $20.63 )
    TS-46BSP
    View caliper rebuild instructions.
    Note: The pistons supplied in the kit are 30mm (vs. OE 29mm) in height.
    Our thorough evaluation indicates 30mm actually fits better than 29mm. As our 30mm pistons leave no movement after installed compared to OE 29mm with movement, yet still provides enough clearance for OE rotor & pad.
    Thickness of OE rotor=32mm; OE pad=16mm
    RB piston gap: 67.69mm
    • Less 32mm for rotor.
    • Less 32mm (16x2) for pads
    Extra clearance=3.69mm
    OE clearance: (The piston sits below the boot with movement)
    RB clearance: (The piston is above above the boot - No movement)
    OE (pison/boot) fully extended:
    RB (piston/boot) fully extended.
    • Piston Kit (Stainless Steel) - Tesla Plaid & LR Front Calipers (Price is for 2 Calipers)
      MSRP: $308.00
      Now: $292.60
    • Save 10% on Rebuild Kit for Tesla M3 & M3P, Porsche MaCan, F-Pace Front 4 Pot Calipers (Price is for 2 Calipers)
    • Black boots
      Save 10% on Rebuild Kit for BMW 135i Front Calipers (Price is for 2 Calipers)
      MSRP: $613.80
      Now: $583.11
    • image_8364
      Save 10% on Rebuild Kit for Ferrari F458/488 Front 6 pot Calipers (Price is for 2 Calipers)
      MSRP: $618.73
      Now: $587.79
    • Boots and Seals Kit - Tesla Plaid & LR Front Calipers (42/44mm) - Price is for 2 Calipers
