    • Save 10% on RB CCB BBK Bundle (410/365) with Optional Rear BBK for Tesla X Plaid (PN 2R57 & 2R46) - Fits OE Calipers
  • oe front wt
  • Front
  • rear ccb wt
  • Save 10% on RB CCB BBK Bundle (410/365) with Optional Rear BBK for Tesla X Plaid (PN 2R57 & 2R46) - Fits OE Calipers oe front wt Front rear ccb wt
    MSRP: $13,460.00
    Now: $12,970.00
    (You save $490.00 )
    TES-CRK-410.365
    Rotor & Pad Installation Video
    • 2 ea front ccb rotors (410x33mm vs. OE 395x32mm)
    • 1 set front OE caliper spacers & mounting hardware
    • 2 ea rear ccb rotors (Stock size 365x28 or BBK 410x29mm)
    • 1 set rear OE caliper bracket & mounting hardware (For BBK only)
    • 1 car set brake pads made for CCB rotors (Larger front pad than OE)
    • 1 car set rotor retaining screws
    • 1 car set SS braided brake lines (optional)
    • This CCM rotor BBK is specially developed for Tesla X Plaid conversion upgrade from stock iron rotors.
    • Rotors are made for an easy installation, and are 100% compatible with OE calipers.
    • Requires 20" wheels with some trim on dust shield edges for larger rotors.
    Weight saving table:
    OE IRON 30 22.5 52.5 105
    RB CCM BBK*
    15 11.8 26.8 53.6
    WT SAVING
    15
    10.7
    25.7
    51.4(49%)
    *Rear wt based on stock rotor 365x28mm
    Feature & benefits:
    • Easy bolt-on installation.
    • All discs are made with RB Gen 4 CCM technology; long (continuous) carbon fibers and angle vanes.
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack like conventional iron rotors due to the heat. More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    Replacement components:
    Brake pads: PD-plaid-cb
    Compare RB rotor material - Continuous carbon fibers vs. OE/Brembo's chopped carbon fibers
    In Cooling Vanes - Angle (directional) vs. Straight (Better cooling efficiency)
    In Finish - Fully machined vs. as casted (Better look and balance)
    Avoid:
    Learn more about the different generation on CCM rotors.
    • RB CCB BBK (390/365) Bundle Kit (With 390/390 Option) for Tesla Plaid & LR Upgrade (PN 2R47 & 2R46) - Fits OE Calipers front kit installed
      MSRP: $9,600.00
      Now: $9,120.00
    • Save 10% on RB CCB BBK Bundle (410/410) for Tesla S Plaid & LR (PN 2R59 & 2R49) - Fits Direct Under OE Calipers (Front 4 pot, Rear 1-pot) Front OE wt
      MSRP: $13,900.00
      Now: $13,200.00
    • Save 10% on OE Caliper BBK (390/365) for Tesla X Plaid Stock Replacement Front & Rear (P/N 2684 & 2435P) Front 390
      MSRP: $3,295.00
      Now: $2,870.00
    • Kit contents Front Kit
      MSRP: $4,125.00
      Now: $3,920.00
      MSRP: $8,400.00
      Now: $7,980.00
