    • Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K)
  • front rotor wt
  • rear rotor wt
  • front pad
  • rear pad
  • Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) front rotor wt rear rotor wt front pad rear pad Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K)
    MSRP: $17,850.00
    Now: $16,960.00
    (You save $890.00 )
    (1 review) Write a Review
    RCCB-TES-420.410
      • 2 ea. Front 6-piston caliper (6061-T6 forged aluminum alloy)
      • 2 ea. Front CCM rotor
      • 2 ea. Front caliper adaptor
      • 2 ea. Rear CCM rotor
      • 2 ea. Rear caliper bracket (Reuse OE caliper)
      • 1 car set brake pads for CCM rotor
      • 1 set of stainless steel braided brake line
    • Front: PD1395-360
    • Rear: PD1929-360
    • Front: 2R44-K
    • Rear: 2R49-K
    Stock 21" wheels can easily fit this BBK. This kit can even clear some aftermarket like Signature SV104 19" wheels.
    Weight saving:
    OE IRON 28.2 22.5 50.7 101.4
    RB CCM BBK
    18.4 14.4 32.8 65.6
    WT. SAVING 9.8 8.1 17.9 35.8(35.3%)
    Feature & Benefits:
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    Avoid:
    Forum discussion:
    • 5
      Perfect Fitment, feel, performance and appearance.
      Posted by Christopher Starnes on Mar 29th 2022
      When I ordered my Plaid I knew I wanted carbon brakes for this beast with one thing lacking - braking power. You can argue that the regen braking is so good that you really don't need more. I believe this is a good argument for a car that never sees a track and is not driven hard, but with some simple spirited driving you will be getting the error code that the brakes are hot right after you notice how hard you are pressing that pedal. I have an Audi RSQ8 with CCB Brakes and knew that is the direction I wanted to go. So, who do you look to for a new cutting-edge product? I believe you should look to the company with known experience in CCB brakes and who are not just selling you a third party product. Racing Brake has that heritage in iron brakes and CCB brakes. They designed, produced and sent the brake kit. I received great communication and assistance. Also, some companies that have appeared just to service Tesla have such a premium to pay for their products. Racing Brake is the best value for what you get. There are a lot of components to designing these new braking systems from the initial bite of the braking to the resistance to heat and cooling, weight and so much more. Trust the best: you will not be disappointed!
    • Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • Carbon Ceramic Brake System Kit (390/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K)
      MSRP: $36,000.00
      Now: $34,200.00
      MSRP: $8,400.00
      Now: $7,980.00
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
    • Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K) Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K)
      MSRP: $6,950.00
      Now: $6,599.00
