    • OE Caliper Replacement for McLaren 570S (650S, 675LT, MP4-12C), 720S (600LT, 765LT) (P/N: RB6LC & RB4L3)
  • Front RB caliper
  • Rear RB caliper
  • OE Caliper Replacement for McLaren 570S (650S, 675LT, MP4-12C), 720S (600LT, 765LT) (P/N: RB6LC & RB4L3) Front RB caliper Rear RB caliper
    MSRP: $8,800.00
    Now: $8,038.00
    (You save $762.00 )
    RCCB-MC-CP
    Kit Includes:
    • 2 ea front 6 pot RB calipers & adaptors
    • 2 ea rear 4 pot RB calipers & adaptors
    • 1 car set brake pads (Optional)
    RB CCB system kit advantage:
    • System is designed, engineered, and manufactured by RB.
    • Caliper bodies are precisely machined from forged aluminum alloy, stronger and more rigid than OE calipers.
    • Calipers are made with internal dust seals, no dust boots to burn out like OE.
    • Caliper pistons are machined from 304SS bar stock with very low heat transfer rate (~1/10 of aluminum), machined with thin wall cut to save the weight, excellent dimensional stability under elevated temperature, maintain one solid piece integrity - Never deformed or corroded.
    • Pistons barrels are finished with lapping finish before receiving chrome plating to assure smooth seal movement for the lasting durability.
    • Our calipers NEVER requires anti knock-back springs like others.
    • Once your OE calipers are replaced with RB's you can use the same brake pads as for Corvette ZR1/Camaro Z28, Ferrari F430 Scuderia, F458, California so lots of choice at lower cost than OE.
    Caliper design and construction.
    Brake Bias Comparison:
    Brake kit wheel fitment template:
    • Front: 2C61-K
    Brake pad replacement:
    https://racingbrake.com/pd-zr1-360/
    Front pad (=Brembo ZR1 Front): 190x78x17mm
    Rear pad (=Brembo ZR1 Rear): 132x60c16.54
    Forum discussions:
    New Racing Brake long fiber carbon rotors with calipers full brake kit: first impressions on track
    A Brake System Upgrade Beyond Rotor & Pad Replacement
    • Dust Boots (High temp.) and Seals Kit for McLaren 570S/650S/675LT/12C; 720S/600LT/765LT & GT Front 6 Pot Calipers (Price is for 2 Calipers)
      Now: $264.00
    • Piston Kit (Stainless Steel) for McLaren 570S/650S/675LT/12C; 720S/600LT & GT Front 6 Pot Calipers (Price is for 2 Calipers)
      MSRP: $485.00
      Now: $480.00
    • Save 10% on Rebuild Kit (w/HIgh temperature dust boots) for McLaren 570S/650S/675LT/12C; 720S/600LT & GT Front 6 Pot Calipers (Price is for 2 Calipers)
      MSRP: $705.00
      Now: $669.60
    • Piston Kit (Stainless Steel) for Mclaren 570S/650S/675LT/12C Front Caliper (Price is for 2 Calipers)
      Now: $320.00
    • [PD8187] Brake Pads for CCM Rotors : Lotus Emira Front, McLaren 570S/650S/675LT/MP4-12C Rear [PD8187] Brake Pads for CCM Rotors : Lotus Emira Front, McLaren 570S/650S/675LT/MP4-12C Rear
      MSRP: $590.00
      Now: $560.00
