    • RB Carbon Ceramic Brake Kit (394/380) for McLaren 600LT, 620R, 720S, 750S, 765LT & GT (P/N: 2C61-K & 2R37-K)
  • Front 6 Pot
  • Front rotor
  • Rear 4 Pot
  • Rear rotor
  • Front RB caliper
  • Rear RB caliper
  • RB Carbon Ceramic Brake Kit (394/380) for McLaren 600LT, 620R, 720S, 750S, 765LT & GT (P/N: 2C61-K & 2R37-K) Front 6 Pot Front rotor Rear 4 Pot Rear rotor Front RB caliper Rear RB caliper
    MSRP: $18,900.00
    Now: $17,890.00
    (You save $1,010.00 )
    RCCB-MC-394.380
    Kit Includes:
    • 2 ea front CCM rotors (394x36mm)
    • 2 ea rear CCM rotors (380x34mm)
    • 2 ea front 6 pot RB calipers & adaptors
    • 2 ea rear 4 pot RB calipers & adaptors
    • 1 car set brake pads (Optional)
    RB CCB system kit advantage:
    • System is designed, engineered, and manufactured by RB.
    • Caliper bodies are precisely machined from forged aluminum alloy, stronger and more rigid than OE calipers.
    • Calipers are made with internal dust seals, no dust boots to burn out like OE.
    • Caliper pistons are machined from 304SS bar stock with very low heat transfer rate (~1/10 of aluminum), machined with thin wall cut to save the weight, excellent dimensional stability under elevated temperature, maintain one solid piece integrity - Never deformed or corroded.
    • Pistons barrels are finished with lapping finish before receiving chrome plating to assure smooth seal movement for the lasting durability.
    • Our calipers NEVER requires anti knock-back springs like others.
    • CCM discs (front and rear) are made with long carbon fibers (vs. OE chopped fibers), stonger and more durable than OE.
    • Brake pads are fully compatible with Corvette ZR1/Camaro Z28, Ferrari F430 Scuderia, F458, California so lots of choice at lower cost than OE.
    Design & Installation notes:
    • Brake kit is made for a direct bolt-on installation to OE spindles w/o requiring any modification.
    • Calipers and rotors are fully interchangeable & compatible with OE
    Caliper design and construction.
    Brake Bias Comparison:
    Brake kit wheel fitment template:
    • Front: 2C61-K
    • Rear: 2C62-K
    Essex/AP iron kits:
    • Front Kit 394x34mm
    • Rear Kit 380x32mm
    Brake pad size comparisons:
    Essex/AP Front pad: (152x54x18mm)
    RB Front pad (=Brembo ZR1 Front): 190x78x17mm (~190% larger)
    AP Rear pad: 132x56x17mm
    RB Rear pad (=Brembo ZR1 Rear): 132x60c16.54 (~120% larger)
    Forum discussions:
    New Racing Brake long fiber carbon rotors with calipers full brake kit: first impressions on track
    A Brake System Upgrade Beyond Rotor & Pad Replacement
    • RB-CCB Replacement Rotors (390/380) for McLaren 720S, 600LT, 2020+ GT Front & Rear (P/N 2R36 & 2R37) front dim
      MSRP: $15,120.00
      Now: $14,360.00
    • [PD8269.PD8270.MC-62] Brake Pads for McLaren 720S/750S/600LT & GT w/Carbon Ceramic Brakes - Front and Rear front caliper
      Now: $0.00
    • RB-CCB Replacement Rotors (390/390) for McLaren 620R, Senna/765LT Front & Rear (P/N 2R36 & 2R80) front wt
      MSRP: $16,000.00
      Now: $15,200.00
    • CCB to Iron Conversion (390/380) for McLaren 720S. 600LT, 765LT & GT 2020+ Front and Rear (PN 2676 & 2677) CCB to Iron Conversion (390/380) for McLaren 720S. 600LT, 765LT & GT 2020+ Front and Rear (PN 2676 & 2677)
      MSRP: $4,430.00
      Now: $3,990.00
    • OE CCB Replacement Rotors (394/380) for McLaren 570S, 650S, 675LT, MP4-12C, 600LT Front & Rear (P/N 2C61 & 2C62) Front rotor wt
      MSRP: $14,590.00
      Now: $13,860.00
