    • RB-CCB System Brake Kit (394x36/380x30) for Mustang GT350 Front and Rear (P/N 2C67-K & 2C98-K)
  • Pic for reference only - Refer to description for the components in the kit
  • 2C67 Front
  • Front kit installed
  • Rear kit w/RB caliper
  • Rear kit w/RB caliper & larger pad
  • Re kit w/OE caliper
  • Front kit assembly
  • Front rotor dimension
  • Rear rotor dimension
  • Front pad dimension
  • Front pad
  • RB rear kit pad dimension
  • Rear pad
  • Pic for reference only - Refer to description for the components in the kit 2C67 Front Front kit installed Rear kit w/RB caliper Rear kit w/RB caliper & larger pad Re kit w/OE caliper RB-CCB System Brake Kit (394x36/380x30) for Mustang GT350 Front and Rear (P/N 2C67-K & 2C98-K) Front kit assembly Front rotor dimension Rear rotor dimension Front pad dimension Front pad RB rear kit pad dimension Rear pad RB-CCB System Brake Kit (394x36/380x30) for Mustang GT350 Front and Rear (P/N 2C67-K & 2C98-K)
    MSRP: $17,885.00
    Now: $16,990.00
    (You save $895.00 )
    RCCB-GT350-OE
    Feature & Benefits
    • Bolt on installation w/o requiring any modification.
    • Requies 19" or larger wheels (download fitment template below to verify with your wheels)
    • Retain OE rear drum parking brake.
    • Rotors are made of continuous carbon fiber, and are directional (leran more)
    • RB calipers are built for ultimate tracking performance and durability.
    • Caliper default color is Red, other optional finishes are available w/price adder.
    Kit contains:
    • 2 ea. RB 6-piston calipers & adaptors
    • 2 ea. RB 4-piston calipers & adaptors
    • 2 ea. Front CCM rotors (394x36mm)
    • 2 ea. Rear CCM rotors (380x30mm)
    • 1 car set brake pads (only if purchase the complete kit)
    • 1 car set brake lines (only if purchase the complete kit)
    Weight info:
    ROTOR WT. COMPARISON (LBS) FRONT REAR TOTAL
    OE 30 19.05 49.05/SIDE
    RB 13.6 12.24 31.0/SIDE
    WT. SAVING 16.4 6.81 25.84/SIDE
    WT. SAVING     51.68/CAR
    Brake pad replacement:
    • Front: PD1395
    • Rear: PD968
    • Front: 2C67
    • Rear: 2C98
    Rear pad comparison:
    Forum Reviews:
    GT350 Carbon Ceramic Brakes - 2022 Update
    • Pic for reference only - Refer to description for the components in the kit Front CCB
      RB-CCB System Brake Kit (420x40/370x30) for Mustang GT500 Front and Rear (P/N 2R08-K & 2R09-K)
      MSRP: $18,940.00
      Now: $17,990.00
    • RB System Brake Kit (420x40/370x30) for Mustang GT500 Front and Rear (P/N 2640-K & 2641-K)
      MSRP: $9,400.00
      Now: $8,930.00
    • RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98) RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98)
      MSRP: $11,891.06
      Now: $11,296.51
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
      MSRP: $16,737.88
      Now: $15,900.99
