    • RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20); M3 E90 (08-13) (P/N 2C94 & 2C80)
  • RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20);  M3 E90 (08-13) (P/N 2C94 & 2C80) RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20);  M3 E90 (08-13) (P/N 2C94 & 2C80) RB-CCB System Kit (380/380) for BMW M2, M3, M4 F80 (15-20);  M3 E90 (08-13) (P/N 2C94 & 2C80)
    MSRP: $16,200.00
    Now: $15,390.00
    (You save $810.00 )
    RCCB-BMW-380.380
    • 2 RB6M 6-piston calipers
    • 2 RB4M 4-piston rear calipers
    • 2 Front CCM Rotor (380x34mm)
    • 2 Rear CCM Rotor (380x30mm)
    • 4 Aluminum caliper adaptors
    • 1 car set CCB brake pads
    • 1 car set brake lines
    Installtion requires 18-19" wheels
    Weight info:
    Weight Comparison (LBS) Front (1ea) Rear (1ea) Per side Total
    OE 24 LBS 20 LBS 44 LBS 88 LBS
    RB 15 LBS 14 LBS 29 LBS  58 LBS
    SAVINGS 9 LBS 6 LBS 15 LBS  30 LBS Wight savings
    Wheel fitment template: 2C94-K
    Replacing the following F80 Calpers:
    BB-43 (40/40x32.5mm)-32mm ht supplied
    BB-22 (44x32.5mm)-32mm ht supplied
    • RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80)
      MSRP: $12,150.00
      Now: $11,530.00
    • RB-CCB System Kit (394/380) for BMW M2/3/4 F80 (14-20) ; M3 E90 (07-13) (P/N 2C82 & 2C14) front caliper wt (loaded)
      MSRP: $17,850.00
      Now: $16,960.00
    • RB-CCB Rotor Kit (400/380) for BMW M3/M4 F80 CCB Rotor Replacement (PN 2R13 & 2C14)
      MSRP: $13,600.00
      Now: $12,920.00
    • RB 6/4 Pot Caliper Track Duty Brake Kit (380/380) for BMW M2/M3/M4 2014+ (P/N 2525-K & 2526-K) Front rotor: 380x36mm
      MSRP: $8,400.00
      Now: $7,986.00
