          • LANCER (08-16) EVO 10
          • LANCER (03+06) EVO 8-9
          • EMIRA
    • RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels
          • EMIRA
  • Front kit assembly dwg (w/RB or stock 1 pcs rotor)
  • RB front: 21.8 lbs
  • RB rear: 16.2 lbs
  • OE front: 32.2 lbs
  • OE rear: 23.4 lbs
  • OE caliper - front
  • OE caliper - rear
  • RB460 caliper wt (loaded)+1.9 for adaptor
Total wt: 10.9 lbs
  • RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels Front kit assembly dwg (w/RB or stock 1 pcs rotor) RB front: 21.8 lbs RB rear: 16.2 lbs OE front: 32.2 lbs OE rear: 23.4 lbs OE caliper - front OE caliper - rear RB460 caliper wt (loaded)+1.9 for adaptor
Total wt: 10.9 lbs
    MSRP: $4,370.00
    Now: $4,150.00
    (You save $220.00 )
    RAM-IRP-374
    Kit Includes:
    • 2 RB460 track duty 4 pot calipers
    • 2 front caliper adaptors
    • 2 front 2 pc rotors (374x32mm)
    • 1 set front brake pads
    • 2 ea Rear 2 pc stock size rotors (374x24 vs. OE 375x22mm)-Optional
    Not Included:
    • Rear pads
    • Brake lines (Optional to be added/advised)
    Caliper Info:
    Weight Info:
    Feature & Benefit:
    • Caliper kit is designed and engineered to swap OE bulky and heavy calipers and fit under OE 18" wheels.
    • Track duty 4 pot calipers using popular brake pads same as for Dodge Charger/Challenger.
    • Sustantial weight saving over the stock calipers & rotors (see table below).
    • Calipers (front) are 100% compatible with stock calipers, so you can start with just purchase the caliper set which mount directly to your existing stock spindle & rotors, then add light weight 2pc rotors later as needed.
    • Progressive upgrade in stages as budget allows.
    • Truly affordable - Cost only fraction of other aftermarket kits.
    • Kit is developed and made by RB for performance improvement and lasting durability.
    Front brake kit fitment template:
    • 2701-K
    • Front: PD1149-391
    Follow this thread on TRX forum for the brake development: RB Performance Brakes is a Supporting Vendor of RAM-TRX.com!
    Other Aftermarket brake offers reference:
    Rotora kits:
    $7,190.00 – $8,390.00 for 18″ standard and Beadlock wheels.
    • Front calipers are 6 piston with 365x36mm Front Rotors
    • Rear calipers are 4 piston with 380x32mm Rear Rotors
    $7,700.00 – $8,200.00 for 20″ and up wheels.
    • Front calipers are 8 piston with 405x36mm Rotors
    • Rear calipers are 4 piston with 405x32mm Rotors
    R1 Concept kits
    • 380mm + 365mm 19” wheel ($7,353)
    • 405mm + 380mm 20” wheel ($6,996)
    Alcon 6-pot Kit (376x42mm vs. OE 378x30) 18" wheel ($3,955)
    Wilwood kit (405x34mm) 20" wheel ($2,583)
    Medias:
    • How to Replace Rear Brakes 2019-2023 Ram 1500
    • Wilwood BBK installation & review
    • Carbon ceramic brakes (440/410) BBK
    Forum discussions:
    • Brakes and Rotor upgrade- not the $5k-$8k ones
    • R1 Big Brake Kits for the TRX!
    • Rotora Brake HD Brake Systems
    • Wilwood TX6R Front Brake Kits for the 2021-2023 Ram TRX
    This Kit Fits:
    Year Make Model Submodel
    2019-2022 Ram 1500 Big Horn
    2019-2022 Ram 1500 HFE
    2019-2022 Ram 1500 Laramie
    2019-2021 Ram 1500 Laramie Longhorn
    2019-2022 Ram 1500 Limited
    2021-2022 Ram 1500 Limited Longhorn
    2019-2022 Ram 1500 Lone Star
    2021+ Ram 1500 Longhorn
    2019-2022 Ram 1500 Rebel
    2020-2021 Ram 1500 Special Service
    2019-2022 Ram 1500 Tradesman
    2019-2022 Ram 1500 TRX
    How to install OE brake line to RB caliper:
    • RB 2pc Rotor Kit (374/374) for RAM TRX (2019+) Stock Replacement Front & Rear (P/N 2701 & 2702) Front rotor wt
      MSRP: $2,700.00
      Now: $2,565.00
    • RB Down Size Brake Kit (355/355) for Dodge Ram TRX 2019+ Fits 17" Wheels (PN 2705-K & 2635) Front Weight
      MSRP: $5,100.00
      Now: $4,845.00
    • RB 6 pot Caliper Kit (370x34) for Tundra (2022+), Land Cruiser 300 (2021+) Front Fits Stock 18" Wheels RB 6 pot Caliper Kit (370x34) for Tundra (2022+), Land Cruiser 300 (2021+) Front Fits Stock 18" Wheels
      MSRP: $3,675.00
      Now: $3,490.00
    • brake kit front kit
      RB Front BBK (410x34) for RAM TRX/1500 2019+ & Jeep Wagoneer 22+ Front
      MSRP: $4,725.00
      Now: $4,490.00
    • RB 6/4 Pot Caliper Kit w/2 pc Rotors for Dodge Ram 3500 Front & Rear (PN 2706-K & 2707-K) Fits 17” wheels. RB 6/4 Pot Caliper Kit w/2 pc Rotors for Dodge Ram 3500 Front & Rear (PN 2706-K & 2707-K) Fits 17” wheels.
      MSRP: $8,500.00
      Now: $8,075.00
