    • RB 2pc Rotor Kit (374/374) for RAM TRX (2019+) Stock Replacement Front & Rear (P/N 2701 & 2702)
  • Front rotor wt
  • OE front brake
  • OE front rotor wt
  • OE front caliper
  • Rear rotor wt
  • OE rear brake
  • OE rear rotor wt
  • RB 2pc Rotor Kit (374/374) for RAM TRX (2019+) Stock Replacement Front & Rear (P/N 2701 & 2702) Front rotor wt OE front brake OE front rotor wt OE front caliper Rear rotor wt OE rear brake OE rear rotor wt
    MSRP: $2,700.00
    Now: $2,565.00
    (You save $135.00 )
    RAM-IRK-374.374
    Bulk Pricing:
    Buy in bulk and save
    Bulk discount rates
    • Buy 2 - 2 and get 5% off
    • Buy 3 - 4 and get 10% off
    • Buy 5 or above and get 15% off
    Kit Includes:
    • 2 ea front 2 pc rotors 374x32mm* (vs. OE 378x30)
    • 2 ea rear 2 pc rotors 374x24mm* (vs. OE 375x22)
    • Brake pads (Porterfield RS-4) - Optional
    Rotor dimensions and fitment note:
    *RB Rotors are made 2mm thicker than OE (front and rear) to increase the thermal capacity; fitments are confirmed w/o issue provided the pistons are fully retracked and the pads are no thicker than OE (i.e. front 20mm, rear 19mm.)
    Rotor diameters are precisely machined to eliminate the undesierable rusty ring (on outer rotor edges), which can also eliminate the potential squeaking resulting from rotor wear-down.
    Overall RB two piece rotors are precisely engineered and certified to fit better than OEM rotors under OE calipers & spindles.
    Advantage of RB 2pc rotors:
    • Rotors are made for a 100% bolt-on installation w/o modification.
    • Rotor dimensions are fine tuned and precisely made to perfectly fit under OE calipers, spindles & pads better than OE rotor fitment.
    • Save substantial unsprung weight over OE rotors (see wt. table)
    • Improve overall braking performance and durability.
    Weight Info:
    *31% wt saving over OE 1 pc rotor despite RB rotors are 2 mm thicker than OEM rotors.
    • Front: D501-06 (374x32)
    • Rear: D502-10 (374x24)
    Looking for replacing OE heavy calipers with RB high performance 4 pot calipers?
    Purchasing the complete brake package here and save money vs. purchase them separately.
    Follow this thread on TRX forum for the brake development: RB Performance Brakes is a Supporting Vendor of RAM-TRX.com!
    Other Aftermarket brake offers reference:
    Rotora kits:
    $7,190.00 – $8,390.00 for 18″ standard and Beadlock wheels.
    • Front calipers are 6 piston with 365x36mm Front Rotors
    • Rear calipers are 4 piston with 380x32mm Rear Rotors
    $7,700.00 – $8,200.00 for 20″ and up wheels.
    • Front calipers are 8 piston with 405x36mm Rotors
    • Rear calipers are 4 piston with 405x32mm Rotors
    R1 Concept kits
    • 380mm + 365mm 19” wheel ($7,353)
    • 405mm + 380mm 20” wheel ($6,996)
    Alcon 6-pot Kit (376x42mm vs. OE 378x30) 18" wheel ($3,955)
    Wilwood kit (405x34mm) 20" wheel ($2,583)
    Medias:
    • How to Replace Rear Brakes 2019-2023 Ram 1500
    • Wilwood BBK installation & review
    • Carbon ceramic brakes (440/410) BBK
    Forum discussions:
    • Brakes and Rotor upgrade- not the $5k-$8k ones
    • R1 Big Brake Kits for the TRX!
    • Rotora Brake HD Brake Systems
    • Wilwood TX6R Front Brake Kits for the 2021-2023 Ram TRX
    • RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels RB Caliper Kit for RAM TRX (2019+) Front & Rear (PN 2701K & 2702) Fits Stock 18" Wheels
      MSRP: $4,370.00
      Now: $4,150.00
    • RB 2pc Rotor Kit (400x34) for Lexus LC500 Front Stock Replacement (P/N: 2469) RB 2pc Rotor Kit (400x34) for Lexus LC500 Front Stock Replacement (P/N: 2469)
      MSRP: $1,400.00
      Now: $1,330.00
    • RB 2pc Rotor - Ferrari 360 Front & Rear (stock replacement)
      MSRP: $990.00
      Now: $940.50
    • RB 2pc Rotor (374/370) for BMW 7 Series Front  & Rear (F01/2), 550 GT (F07)  (P/N 2323 & 2331)
      MSRP: $3,241.70
      Now: $3,079.62
    • RB 2pc Rotor Kit (394x36/380x28) for Ford Mustang Shelby GT350 2016+ Stock Replacement Front & Rear (P/N 2568 & 2569) Front
      MSRP: $2,900.00
      Now: $2,755.00
