          • EVORA (2009-2021)
    • RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4)
          • EVORA (2009-2021)
  • RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4) RB Pad Pins for Porsche, Tesla Plaid Brembo Calipers (Pack of 4)
    MSRP: $165.00
    Now: $156.75
    (You save $8.25 )
    (2 reviews) Write a Review
    PPS-13
    Kit contents:
    • 4 sets Pins & screws
    • 4 ea Pins only (optional)
    • 4 ea Screws only (optional) (12 points vs. OE 10 points)
    Materials/specs:
    • Pins - Stainless steel.
    • Screw - Grade 9, black oxidized - Compatibility is certified by RB.
      • Head: 12 points (vs. OE 10 points)
      • Flange dia.: 15mm (vs. OE 18mm)
    Features:
    • Replacing factory damaged/rusty pins.
    • Correcting caliper assembly discrepancy (Tesla Plaid front calipers).
    • Allowing to install thicker (2-4mm) rotors (Tesla Plaid, Porsche Boxster etc.
    These pins are made 2mm shorter than OE but are verified that they can keep the pad in place even if the pad lining (friction material) is worn down to the minimal thickness w/o any concern.
    Installation Instructions:
    1. Use 10 point socket to loosen the screw (Red):
    2. Punch out the original pins with a bolt & hammer.
    3. Replace with RB new pins.
    4. Place the 10 pt screw from the other end.
    5. Torque with a 10 pt socket to draw the new bolt until seated to the caliper housing.
    For caliper improvement:
    Replacing pins to run 4mm thicker rotors, typically like Porsche Boxster's. Replacing both inboard & outboard. (Need qty 2 or 8 new pins)
    Correcting uneven pin assembly, like Tesla Plaid calipers. Replacing only Inboard pins (qty 1 or 4 new pins)
    Inboard Sides only where you can see the screws are set in deeper that the Outboard.
    Replace the pins per above instruction.
    Before correction:
    After correction - Clearance is increased, and both IB/OB bolts are now symmetrical (centered evenly to the caliper center body).
    Tesla Forum discussion:
    can I install a rotor thicker than stock's 32mm?
    2 Reviews Hide Reviews Show Reviews
    • 5
      Perfect Fit
      Posted by Benjamin on May 17th 2025
      Pins are a perfect fit. I can confirm they also work with any Brembo caliper that uses this style of pad retainer pin, including the Porsche Cayenne, Porsche Panamera, and Volkswagen Touareg, front and rear.
    • 5
      Caliper pad pins were a perfect fit
      Posted by Matthew on Oct 29th 2023
      I replaced my damaged OEM caliper pad pins for these and the fit was perfect. Very well made parts.
    • SALE
      RB Pad Pin Punch for Most OE Brembo Calipers, Available on Amazon RB Pad Pin Punch for Most OE Brembo Calipers, Available on Amazon
      MSRP: $13.50
      Was: $12.88
      Now: $9.99
    • RB CALIPER PAD PINS - 2 EA  (FOR 1 CALIPER)
      MSRP: $22.09
      Now: $20.99
    • Save 10% on Rebuild Kit for for Tesla Plaid & LR Front Calipers (Price is for 2 Calipers) Gap between OE boots=69.38 (max rotor & pad clearance)
    • Piston Kit (Stainless Steel) - Tesla Plaid & LR Front Calipers (Price is for 2 Calipers)
      MSRP: $308.00
      Now: $292.60
    • SALE
      RB-CCB Rotor OE Caliper Kit (390x36) for Tesla S/X Plaid & Long Range Front w/OE Black Calipers (Does Not Fit Non Plaid Models) RB-CCB Rotor OE Caliper Kit (390x36) for Tesla S/X Plaid & Long Range Front w/OE Black Calipers (Does Not Fit Non Plaid Models)
      MSRP: $6,000.00
      Was: $5,700.00
      Now: $5,400.00
