          • EVORA (2009-2021)
    • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K)
          • EVORA (2009-2021)
  • Front
  • Rear
  • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) Front Rear RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 991 C2S/C4S Front & Rear (P/N: 2507-K & 2508-K)
    MSRP: $4,200.00
    Now: $3,990.00
    (You save $210.00 )
    POR-991-CS-BBK
    This BBK is specially designed and packaged for upgrading your original 340/330mm (or 350/330mm) to the same rotor sizes as 991/992 GT3 380/380mm.
    • Easy 100% bolt on installation.
    • No bleeding to your brake system - Save trouble in bleeding the system if you were to install a traditional upgraded BBK.
    • Retain OE calipers that you are familiar with for the same look and maintenance.
    • Lower maintenance/replacement cost
    • Increase you brake thermal capacity than original so they will last a lot longer.
    • Best value and the most affordable BBK for 991/992 CS 2/4.
    • Exclusively designed and built by RB.
    • Improve the overall performance and look with a BBK w/o the cost and hassle of an aftermarket or swapped BBK.
    • 2 ea front light weight 2 pc rotors (380x34mm vs. original 340/350x34mm)
    • 2 ea rear light weight 2 pc rotors (380x28mm vs. original 330x28mm)
    • Necessary caliper spacers & hardware kit
    • 1 set brake pads (optional)
    • Front: PD1773
    • Rear: PD1740
    • Front: D501-04
    • Rear: D502-03
    Forum discussions:
    • CS/GTS BBK with GT3 Size Rotors
    • 991 to 911S Rotor Diameter
    • RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K) RB BBK (380/380) for Porsche 996 & 997 Upgrade (P/N 2338-K & 2433-K)
      MSRP: $8,250.00
      Now: $7,830.00
    • RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K)
      MSRP: $3,895.00
      Now: $3,700.00
    • [PD1664A-3R9] RB XR90 Track Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only
      MSRP: $513.70
      Now: $488.02
    • [PD1664A-391] RB XT910 Brake Pad: 991 Porsche C2S, C4S, GTS with RB 380/380 BBK Only
      MSRP: $385.00
      Now: $365.75
    • RB/OE Caliper BBK (380/350) for Alfa Romeo Giulia 2.0L Upgrade Front & Rear (P/N 2693-K & 2696) Front brake kit
      MSRP: $4,730.00
      Now: $4,490.00
