          • EVORA (2009-2021)
    • RB-CCB (410/380) Rotor Kit for Porsche 992 GT3, 718 (981-982) GT4 RS PCCB Stock Replacement or Iron Upgrade.
          • EVORA (2009-2021)
  • CAR SET
  • CAR SET
    MSRP: $13,650.00
    Now: $12,960.00
    (You save $690.00 )
    POR.992.crk.410-380
    • 2 ea Front CCM rotors
    • 2 ea Rear CCM rotors
    • 1 car set of CCB pads (optional)
    • 1 set Caliper mounting hardware (for upgrade kit only)
    Features and benefits:
    This CCM rotor kit is specially developed for 981 GT4 upgrading from Red calipers w/iron rotors direct replacement to the latest CCM brake technology.
    • RB CCM rotors are stronger and can run cooler than OE pccb.
    • CCM rotors (Brembo, ST or RB) have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing.
    • Rotor annulus are wide enough to fit Pccb pads (74mm vs. iron's 62mm in depth) for lower braking temperature.
    • Literally no brake dust.
    • Reduce unsprung weight.
    • Improve driving comfort.
    • Front: PD1768
    • Rear: PD1740
    CAR SET
    • CAR SET 2C19 FRONT CENTER LOCK
      RB-CCB (410/390) Rotor Kit for Porsche 991 GT3, 718 GT4 pccb Stock Replacement or Iron Conversion Upgrade.
      MSRP: $14,500.00
      Now: $13,800.00
    • front kit 380mm w/6 pot rear kit 380mm w/4 pot kit
      MSRP: $16,100.00
      Now: $15,300.00
    • RB-CCB Rotor Kit (380/350) for Porsche 997.2 GT3 Pccb Replacement (P/N 2C12 & 2C25) front dimensions
      MSRP: $12,600.00
      Now: $11,970.00
    • RB-CCB (380/380) for Porsche 991 GT3/Turbo, 992 GT3, and/or CS Conversion Upgrade from Iron Rotors (PN 2C78 & 2C56) front 2c78
      MSRP: $12,500.00
      Now: $11,890.00
    • RB 2 Pc Rotor Kit (380/380) for Porsche 991 GT3 & 981 Cayman GT4 (Stock Replacement) PN: 2421/2422 Front 2421
      MSRP: $3,840.00
      Now: $3,648.00
