    • RB-CCB System Kit (410/390) for Porsche 991/992/GT4 (2C19-K & 2C20-K)
  • Front 6 Pot
  • Front 6 pot
  • Rear 4 Pot
  • Rear 4 pot
  • Front caliper
  • Rear caliper
  • RB-CCB System Kit (410/390) for Porsche 991/992/GT4 (2C19-K & 2C20-K) Front 6 Pot Front 6 pot Rear 4 Pot Rear 4 pot Front caliper Rear caliper
    MSRP: $18,850.00
    Now: $17,900.00
    (You save $950.00 )
    POR-991-crp.410.390
    Kit Includes:
    • 2 ea front CCM rotors (410x36mm)
    • 2 ea rear CCM rotors (390X32mm)
    • 2 ea front 6 pot RB calipers & adaptors
    • 2 ea rear 4 pot RB calipers & adaptors
    • 1 car set stainless braided brake lines
    • 1 car set ccb street brake pads
    RB CCB system kit advantage:
    The rotors and calipers in this system kit are 100% compatible and intgerchangeable with OE Yellow calipers and pccb rotors. However after replaciing with RB calipers you can use the same brake pad shapes as Corvette ZR1/Camaro Z28, Ferrari F430 Scuderia, F458, California that come with CCM rotors, so lots of choice at lower cost than OE.
    • System is designed, engineered, and manufactured by RB.
    • Caliper bodies are precisely machined from forged aluminum alloy, stronger and stiffer than OE calipers.
    • Calipers are made with open top for easy inspection and pad replacement w/o having to remove the calipers like OE.
    • Calipers are made with internal dust seals, no dust boots to burn out like OE.
    • Caliper pistons are machined from 304SS bar stock with very low heat transfer rate (~1/10 of aluminum), machined with thin wall cut to save the weight, excellent dimensional stability under elevated temperature, maintain one solid piece integrity - Never deformed or corroded.
    • Pistons barrels are finished with lapping finish before receiving chrome plating to assure smooth seal movement for the lasting durability.
    • CCM discs (front and rear) are made with long carbon fibers (vs. OE chopped fibers), stonger and more durable than OE.
    Design & Installation notes:
    • Brake kit is made for a direct bolt-on installation to OE spindles w/o requiring any modification.
    • Calipers are fully interchangeable & compatible with OE calipers.
    Caliper design and construction.
    Brake Kit wheel fitment template:
    • Front: 2C19-K
    • Rear: 2C20-K
    RB Front caliper pad (=Brembo ZR1 Front): 190x78x17mm
    RB Rear caliper pad (=Brembo ZR1 Rear): 132x60x16.5mm
    • RB-CCB System Kit (394/390) for Porsche 993 All Models (P/N 2C07-K & 2C08-K) Fits 19" Wheels RB-CCB System Kit (394/390) for Porsche 993 All Models (P/N 2C07-K & 2C08-K) Fits 19" Wheels
      MSRP: $17,600.00
      Now: $16,700.00
    • CAR SET 2C19 FRONT CENTER LOCK
      RB-CCB (410/390) Rotor Kit for Porsche 991 GT3, 718 GT4 pccb Stock Replacement or Iron Conversion Upgrade.
      MSRP: $14,500.00
      Now: $13,800.00
    • RB-CCB (420/390) Rotor Kit for Porsche 992 Turbo S Pccb Replacement  (PN 2R41 & 2C20) RB-CCB (420/390) Rotor Kit for Porsche 992 Turbo S Pccb Replacement  (PN 2R41 & 2C20)
      MSRP: $14,370.00
      Now: $13,650.00
    • front kit 380mm w/6 pot rear kit 380mm w/4 pot kit
      MSRP: $16,100.00
      Now: $15,300.00
    • RB 2 Pc Rotor Kit (410/390) for Porsche 991 GT3 (CCB to Iron Conversion)
      MSRP: $4,200.00
      Now: $3,990.00
