    • RB-CCB System Kit (380/380) for Porsche 991 GT3/Turbo, 981 Cayman GT4
  • front kit 380mm w/6 pot
  • rear kit 380mm w/4 pot kit
  • front rotor wt: 14.1 lbs
  • rear rotor wt: 13 lbs
  • front kit 380mm w/6 pot rear kit 380mm w/4 pot kit RB-CCB System Kit (380/380) for Porsche  991 GT3/Turbo, 981 Cayman GT4 front rotor wt: 14.1 lbs rear rotor wt: 13 lbs
    MSRP: $16,100.00
    Now: $15,300.00
    (You save $800.00 )
    POR-991-crp-380.380
    • 2 ea front ccb rotors (380x34nn)
    • 2 ea front RB 6 pot heavy duty calipers
    • 2 ea front caliper adaptors & hardware kit
    • 2 ea rear ccb rotors (380x30mm)
    • 2 ea rear RB 4 pot heavy duty calipers
    • 2 ea rear caliper spacers & hardware kit
    • 1 car set ccb street brake pads
    • 1 car set stainless steel braided brake line
    Features & benefits:
    • This system kit is designed and made for a 100% bolt-on installation requires no modification.
    • Rotors are made of long (continuous) carbon fibers (vs. OE pccb chopped fibers)
    • Rotors are directional for more efficient cooling.
    • Standard FMSI brake pad shapes - Easy to source at lower cost.
    • Rotors are interchangeable & compatible with 991 GT3 standard iron rotors.
    • Front: CR10/CR21
    • Rear: CR27
    • Front: PD1666-360
    • Rear: PD968-360
    • Front: 2C68
    • Rear: 2C91
    This generally will fit 19" wheels possible with 18" after market wheels, please make sure to download the fitment template and check the clearance before purchase.
    • RB 2 Pc Rotor Kit (380/380) for Porsche 991 GT3 & 981 Cayman GT4 (Stock Replacement) PN: 2421/2422 Front 2421
      MSRP: $3,840.00
      Now: $3,648.00
    • RB-CCB (380/380) for Porsche 991 GT3/Turbo, 992 GT3, and/or CS Conversion Upgrade from Iron Rotors (PN 2C78 & 2C56) front 2c78
      MSRP: $12,500.00
      Now: $11,890.00
    • RB Brake System Kit (380x34/380x30) Direct Replacement for Porsche 991 GT3, 981 GT4 Front kit
      MSRP: $9,000.00
      Now: $8,550.00
    • Brake Lines (6 line kit) - Porsche 991 GT3, Turbo, Turbo S, & Cayman GT4
      MSRP: $341.00
      Now: $323.95
    • CAR SET
      RB-CCB (410/380) Rotor Kit for Porsche 992 GT3, 718 (981-982) GT4 RS PCCB Stock Replacement or Iron Upgrade.
      MSRP: $13,650.00
      Now: $12,960.00
