    • RB-CCB (380/380) for Porsche 991 GT3/Turbo, 992 GT3, and/or CS Conversion Upgrade from Iron Rotors (PN 2C78 & 2C56)
  • front 2c78
  • rear 2C56
  • RB-CCB (380/380) for Porsche 991 GT3/Turbo, 992 GT3, and/or CS Conversion Upgrade from Iron Rotors (PN 2C78 & 2C56) front 2c78 rear 2C56
    MSRP: $12,500.00
    Now: $11,890.00
    (You save $610.00 )
    POR.991.crk-380.380
    • 2 ea front ccb rotors (380x34mm)
    • 2 ea rear ccb rotors (380x30mm)
    • 1 car set caliper spacers (Optional for CS' only)
    Brake pads are optional (Not included.)
    This kit is specially developed for 991 GT3/Turbo & 992 GT3 upgrading from iron rotors (w/red calipers) for a direct replacement to the latest CCM brake technology.
    • RB CCM rotors are stronger and can run cooler than OE pccb.
    • CCM rotors (Brembo, ST or RB) have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing.
    • Rotor annulus are wide enough to fit Pccb pads (74mm vs. iron's 62mm in depth) for cooler braking temperature.
    • Runs on street or tracks w/o temperature factors or water (rain or car wash) effect.
    • Literally no brake dust.
    • Reduce unsprung weight.
    • Improve driving comfort.
    Avoid:
    Learn more about the different generation on CCM rotors.
    • front kit 380mm w/6 pot rear kit 380mm w/4 pot kit
      MSRP: $16,100.00
      Now: $15,300.00
    • RB 2 Pc Rotor Kit (410/390) for Porsche 991 GT3 (CCB to Iron Conversion)
      MSRP: $4,200.00
      Now: $3,990.00
    • CAR SET
      RB-CCB (410/380) Rotor Kit for Porsche 992 GT3, 718 (981-982) GT4 RS PCCB Stock Replacement or Iron Upgrade.
      MSRP: $13,650.00
      Now: $12,960.00
    • CAR SET 2C19 FRONT CENTER LOCK
      RB-CCB (410/390) Rotor Kit for Porsche 991 GT3, 718 GT4 pccb Stock Replacement or Iron Conversion Upgrade.
      MSRP: $14,500.00
      Now: $13,800.00
    • RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80)
      MSRP: $12,150.00
      Now: $11,530.00
