Quick view RB 1pc rotor (Drill+Slot) - 6 FRONT 02-05 MSRP: $316.80 Was: Now: $300.96 Add to Cart Compare Quick view RB 1pc rotor (Drill+Slot) - MIATA MX5 REAR 89-93 MSRP: $209.00 Was: Now: $198.55 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - CIVIC H-BACK FRONT 88-89 MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - INTEGRA FRONT 86-89 MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - INTEGRA FRONT 90-01 MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - NEON (5 LUG) FRONT 94-99 MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Slot) - 350Z (non-Brembo) REAR 06-08 MSRP: $275.00 Was: Now: $261.25 Add to Cart Compare Quick view RB 1pc rotor (Slot) - GOLF GTI (VR6) FRONT 8/95-98 MSRP: $247.50 Was: Now: $235.13 Add to Cart Compare Quick view RB 1pc rotor (Slot) - MAXIMA FRONT (00-03) MSRP: $408.10 Was: Now: $387.70 Add to Cart Compare Quick view RB 1pc rotor (Drill+Slot) - 6 FRONT 02-05 Material: Alloyed Gray IronMachining: Drilled & Curved SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $316.80 Was: Now: $300.96 Add to Cart Compare Quick view RB 1pc rotor (Drill+Slot) - MIATA MX5 REAR 89-93 Material: Alloyed Gray IronMachining: Drilled & Curved SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $209.00 Was: Now: $198.55 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - CIVIC H-BACK FRONT 88-89 Material: Compacted Graphite Iron (CGI) & Heat treatedMachining: Fine cross cut disc surface approved for SCCA club racingSurface: Plain (no coating) w/cross cut grinding These rotors are approved by SCCA for club racings. MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - INTEGRA FRONT 86-89 Material: Compacted Graphite Iron (CGI) & Heat treatedMachining: Fine cross cut disc surface approved for SCCA club racingSurface: Plain (no coating) w/cross cut grinding These rotors are approved by SCCA for club racings. MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - INTEGRA FRONT 90-01 Material: Compacted Graphite Iron (CGI) & Heat treatedMachining: Fine cross cut disc surface approved for SCCA club racingSurface: Plain (no coating) w/cross cut grinding These rotors are approved by SCCA for club racings. MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Plain Finish) - NEON (5 LUG) FRONT 94-99 Material: Compacted Graphite Iron (CGI) & Heat treatedMachining: Fine cross cut disc surface approved for SCCA club racingSurface: Plain (no coating) w/cross cut grinding These rotors are approved by SCCA for club racings. MSRP: $267.30 Was: Now: $253.94 Add to Cart Compare Quick view RB 1pc rotor (Slot) - 350Z (non-Brembo) REAR 06-08 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $275.00 Was: Now: $261.25 Add to Cart Compare Quick view RB 1pc rotor (Slot) - GOLF GTI (VR6) FRONT 8/95-98 Material: Alloyed Gray IronMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface MSRP: $247.50 Was: Now: $235.13 Add to Cart Compare Quick view RB 1pc rotor (Slot) - MAXIMA FRONT (00-03) Bracket (CBN01) is needed for this rotor to fit, which is included in kit number 2048-111-0. Material: Alloyed Gray IronMachining: Straight SlotSurfac MSRP: $408.10 Was: Now: $387.70 Add to Cart Compare 1 2 Next 1 2 Next Compare Selected × OK
