    • RB 2 Pc Rotor Kit (324/330) BBK for Acura NSX NA1 (91-96) or NA2 (97-05) (P/N 2076-K & 2077-K) - Caliper Modification is required (See Description)
  • image_8634
  • image_8634
    MSRP: $2,860.00
    Now: $2,717.00
    (You save $143.00 )
    NSX-IRK-324.330
    Modification required:
    See Description
    • This affordable BBK is an excellent brake upgrade investment for your NSX.
    • The big rotors can provide larger thermal capacity and more torque leverage to prevent brake fade. With larger thermal capacity and will keep the disc cooler and last longer.
    • Requires 17" wheels.
    • Front: PD787
    • Rear: PD504
    • Front: D304-07
    • Rear: D304-04
    There are some modifications required for this kit (front kit only).
    You will need to grind down 3mm minimum on your caliper marked in red:
    Modification required See Description
    image_8634
    • RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077) RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077)
      MSRP: $3,540.00
      Now: $3,360.00
    • RB 2 Pc Rotor Kit (300/303) BBK for Acura NSX NA1  Upgrade to NA2 (P/N 2089 & 2090)
      MSRP: $2,631.20
      Now: $2,499.64
    • RB 2pc Rotors (330/330) for NSX (91-05) Brembo BBK Replacement front and rear (P/N 2156, 2157) RB 2pc Rotors (330/330) for NSX (91-05) Brembo BBK Replacement front and rear (P/N 2156, 2157)
      MSRP: $2,695.00
      Now: $2,560.00
    • RB OE Caliper BBK (350/350) for Porsche  996/997 CS 2/4. Boxster that come with 330/330 rotors (P/N 2179-K & 2180-K)
      MSRP: $3,150.00
      Now: $2,992.50
    • RB 4/2 Pot Caliper Kit (330/330) for Lexus GS 93-05, LS 95-17  (P/N 2309-K & 2298-K)
      MSRP: $4,400.00
      Now: $4,180.00
