    • RB CCB Rotor Kit (390x34/380x30) for Nissan Skyline R34 Upgrade to CCB with GTR R35 Calipers - 100% Bolt-On Installation w/o Modifications; Fit ZR1 Pads (P/N: 2R78 & 2R79)
  • Front wt
  • Rear wt
  • front dimensions
  • rear dimensions
  • front caliper adaptor
  • rear caliper adaptor
  • RB CCB Rotor Kit (390x34/380x30) for Nissan Skyline R34 Upgrade to CCB  with GTR R35 Calipers - 100% Bolt-On Installation w/o Modifications; Fit ZR1 Pads (P/N: 2R78 & 2R79) Front wt Rear wt front dimensions rear dimensions RB CCB Rotor Kit (390x34/380x30) for Nissan Skyline R34 Upgrade to CCB  with GTR R35 Calipers - 100% Bolt-On Installation w/o Modifications; Fit ZR1 Pads (P/N: 2R78 & 2R79) front caliper adaptor rear caliper adaptor
    MSRP: $13,680.00
    Now: $12,996.00
    (You save $684.00 )
    NIS-R34-390.380
    Features and benefits:
      1. CCB Rotor kits are exclusively developed for conversion upgrade for R32/33/34 from OE iron rotors with a 100% direct bolt on installation.
      2. Discs are made of long carbon fibers and are directional, they are stronger and more durable than
        Brembo's chopped carbon fibers and straight vanes.
      3. Rotors will fit under R35 OE/Brembo calipers w/o requiring any caliper or dust shield modifications.
      4. Rotors (front & rear) are made with larger annulus to accommodate deeper pads (same sizes as ZR1) that can help to run the brake cooler than OE size pads.
      5. Rear rotor hats are made with iron sleeve insert (drum size is smaller than R35) and is 100% compatible with OE parking emergency brakes.
    • 1 car set caliper adaptors & hardware kit for R35 Brembo calipers installation
    • 2 ea front ccb rotors (390x34mm) - No caliper modification is required
    • 2 ea rear ccb rotors (380x30mm) - No caliper & dust shield trimming is required
    • 1 set CCB RB ST600 brake pads (Oversized from GTR stock size pads)
    Weight comparison (based on R35 iron rotors):
    • PD-ZR1-360
    **Pagid/Endless pads are subject to availability.
    • Front: CR18
    • Rear: CR27 (for stock size 380x30mm)
    Rotor pricing references:
    Compared to Surface Transforms:
    https://surfacetransforms.com/nissan-gtr-brake-kits
      Now: $12,400.00
      MSRP: $4,060.00
      Now: $3,860.00
    • SALE
      Generic image front set up
      Corvette C8 Z51 CCB Rotor (345/350) Upgrade Kit Fits OE Calipers (Not Included) w/o Modifications (P/N 2R22 & 2R23)
      MSRP: $11,800.00
      Was: $11,200.00
      Now: $9,720.00
    • RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98) RB-CCB Rotor Kit (394/380mm) for Ford GT350 Upgrade Conversion Fits OE Calipers & Rear Emergency Drum Brake w/o Modifications (P/N 2C67 & 2C98)
      MSRP: $11,891.06
      Now: $11,296.51
