Quick view RB 2pc Rotor Kit (290x22/280x10) for Mazda Miata NC (06-15) Stock Replacement (P/N 2228 & 2557) MSRP: $1,480.00 Was: Now: $1,406.00 Choose Options Compare Quick view RB BBK (324x24/330x12) for Mazda Miata NC (06-15) (P/N 2023-K & 2559-K) MSRP: $2,800.00 Was: Now: $2,660.00 Choose Options Compare Quick view RB Brake Kit (Stock Size 290x22mm) for Mazda Miata NC (06-15) Front MSRP: $2,095.00 Was: Now: $1,990.00 Choose Options Compare Quick view RB Caliper Kit w/Stock Size (324x24) 2 pc light wt rotors for Mazda RX-8 & Miata NC (06-15) BBK MSRP: $2,800.00 Was: Now: $2,660.00 Choose Options Compare Quick view RB OE Size Kit (290x22/280x10) w/RB 4 Pot Calipers for Mazda Miata NC 06-15 (P/N 2228-K & 2557) MSRP: $2,500.00 Was: Now: $2,375.00 Compare Quick view RB Track Duty BBK (328x28) for Mazda RX8 and Miata NC (06-15) Front MSRP: Was: Now: $3,080.00 Choose Options Compare Quick view RB 2pc Rotor Kit (290x22/280x10) for Mazda Miata NC (06-15) Stock Replacement (P/N 2228 & 2557) Kit includes: 2 ea front rotors 2 ea rear rotors 1 set brake pads Replacement rotor rings: Front: 1101-02 Rear: D006-03 Replacement brake pads: Front: PD1179 Rear: PD1180 MSRP: $1,480.00 Was: Now: $1,406.00 Choose Options Compare Quick view RB BBK (324x24/330x12) for Mazda Miata NC (06-15) (P/N 2023-K & 2559-K) Kit includes: 2 ea. RB 4-Piston front calipers 2 ea Caliper adaptors 2 ea. Front 2 pc rotors (324x24mm vs. OE 290x22) 2 ea. Rear 2 pc rotors (330x12mm vs. OE 280x10) 1 set brake pads 1 set brake lines Replacement rotor rings: Front: D304-02 Rear:... MSRP: $2,800.00 Was: Now: $2,660.00 Choose Options Compare Quick view RB Brake Kit (Stock Size 290x22mm) for Mazda Miata NC (06-15) Front This kit includes: 2 2 pc center-mount rotors (Stock size) 2 4-Piston calipers (6061 aluminum alloy) 2 Aluminum alloy caliper adapters 1 Set of RB street performance brake pads MSRP: $2,095.00 Was: Now: $1,990.00 Choose Options Compare Quick view RB Caliper Kit w/Stock Size (324x24) 2 pc light wt rotors for Mazda RX-8 & Miata NC (06-15) BBK Kit contains: 2 ea 2 pc stock size rotors (324x24mm) 2 ea RB 4-pot calipers 2 ea caliper adaptors 1 axle set street pads Rear rotor kit - Optional Learn how RB Aluminum caliper kits are made differently from others Wheel fitment template:... MSRP: $2,800.00 Was: Now: $2,660.00 Choose Options Compare Quick view RB OE Size Kit (290x22/280x10) w/RB 4 Pot Calipers for Mazda Miata NC 06-15 (P/N 2228-K & 2557) Kit includes: 2 ea. RB 4-Piston front calipers 2 ea. Caliper adaptors 2 ea. Front 2 pc rotors 2 ea. Rear 2 pc rotors 1 set brake pads Brake lines are not included Replacement rotor rings: Front: 1101-02 Rear: D006-03 Replacement brake... MSRP: $2,500.00 Was: Now: $2,375.00 Compare Quick view RB Track Duty BBK (328x28) for Mazda RX8 and Miata NC (06-15) Front Kit includes: 2 ea RB 4 pot calipers 2 ea Caliper adaptors 2 ea Heavy duty 2 pc rotors (328x28mm vs. OE 324x24mm) 1 set street pads Replacement components Rotor rings: D304-06 Brake pads: PD647 Wheel fitment template: 2033-K Minimum wheels to fit... MSRP: Was: Now: $3,080.00 Choose Options Compare Compare Selected × OK
