    • RB 2 pc Rotor Kit (400/360mm) for Mercedes C63/S63/S65 AMG 2013+ CCM to Iron Rotor Conversion kit (P/N 2678 & P/N 2671)
  • Front rotor dimension
  • Front pad (duly modified)
  • Rear rotor dimension
  • Rear pad
  • Rear rotor
  • OE front  CCB caliper
  • RB 2 pc Rotor Kit (400/360mm) for Mercedes C63/S63/S65 AMG 2013+ CCM to Iron Rotor Conversion kit (P/N 2678 & P/N 2671) Front rotor dimension Front pad (duly modified) Rear rotor dimension Rear pad Rear rotor OE front  CCB caliper
    MSRP: $3,850.00
    Now: $3,650.00
    (You save $200.00 )
    MB-IRC-400.360
    This rotor kit is made for ccb rotor downgrade conversion to iron rotors with 100% bolt-on installation however in order to reduce the rotor weight our front rotor rings are made with a smaller annulus which will not fit the full size ccb pads that are made for iron rotors, so it will require to trim the pads from ccb's 87mm to 75mm.
    Kit Includes:
    • 2 ea Front two piece rotors (400x38mm vs. OE CCB 400x40mm)
    • 2 ea Rear two piece rotors (360x26mm)
    Brake pads (Optional)
    • Front: PD1530A
    • Rear: PD1681
    Replacement rotor ring:
    • Front: D604-03
    • Rear: D407-03
    • RB 2 pc Rotor Kit (420/360) for Mercedes S63/S65 AMG 2015+/GT-R 17+ CCM to iron conversion kit (P/N 2601 & P/N 2671) front pad
      MSRP: $4,500.00
      Now: $4,270.00
    • RB 2pc Rotor Kit (360/360mm) for Mercedes GT, C63 AMG 2015+ (P/N 2141 & 2671) Front dwg
      MSRP: $2,766.50
      Now: $2,628.18
    • RB 2 pc Rotor Kit (390/360mm) for Mercedes C63 AMG Black Series (P/N 2237 & 2430) 2237 FRONT
      MSRP: $3,331.90
      Now: $3,165.31
    • RB 2 pc Rotor Kit (390/360mm) for 2017+ Mercedes E63 AMG (P/N 2470-K & 2671-K) front 390x36
      MSRP: $3,465.00
      Now: $3,291.75
    • RB 2 pc Rotor Kit (360/360mm) for Mercedes E63 AMG 2010+ / CLS63 AMG 2012+ (P/N 2141 & 2430) Front wt
      MSRP: $3,100.00
      Now: $2,898.00
