    • M14x1.5 Wheel Studs Conversion Kit (10 per Pack)
  • kit contents
  • add loctite
  • installation length
  • M14x1.5 Wheel Studs Conversion Kit (10 per Pack) kit contents add loctite installation length M14x1.5 Wheel Studs Conversion Kit (10 per Pack) M14x1.5 Wheel Studs Conversion Kit (10 per Pack)
    MSRP: $145.00
    Now: $137.75
    (You save $7.25 )
    M14x50-WSK
    Bulk Pricing:
    Buy in bulk and save
    Bulk discount rates
    • Buy 2 - 2 and get 10% off
    • Buy 3 or above and get 15% off
    Feature & Benefits
    • This wheel stud kit will convert your OE loose wheel studs to permanently attached to the hub.
    • It can save you time and effort in brake and wheel maintenance w/o having to remove/attach the studs individually (one-by-one).
    • 10 ea M14x1.5 (or M14x1.25) to M14x1.5x50mm length wheel studs.
    • 10 ea M14x1.5 wheel nuts.
    • 2 packs (0.5ml) Loctite 242 blue thread locker.
    Wheel stud grade: 10.9
    1. Clean the hub surface.
    2. Apply loctite to the hub thread end.
    3. Use 5mm wrench bit torque to ~75 ft-lbs using a calibrated torque wrench in a star pattern.
    • EVO 8/9/10 M12x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set)
      MSRP: $79.20
      Now: $75.24
    • image_9146 SRT-4 M121x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set)
      MSRP: $79.20
      Now: $75.24
    • EVO 8/9/10 M12x1.5 Wheel Stud M12x1.5, 14mm longer than stock (10 pc. - Axle Set)
      MSRP: $93.50
      Now: $88.83
    • RB-CCB Disc (380x28mm) - Price per pair.
      MSRP: $4,620.00
      Now: $4,389.00
    • RB 2 Pc Rotor Kit for Dodge Viper G6 - CCB Conversion to Iron (P/N 2497 & 2498)
      MSRP: $3,200.00
      Now: $3,040.00
