    • M12x1.5 Wheel Studs Conversion Kit - (10 per Pack)
  • kit contents
  • dimensions
  • installation length
  • add loctite
  • torque to 75-80 ft-lbs
  • kit contents dimensions installation length add loctite torque to 75-80 ft-lbs
    MSRP: $145.00
    Now: $137.75
    (You save $7.25 )
    M12x50-WSK
    Bulk Pricing:
    Buy in bulk and save
    Bulk discount rates
    • Buy 2 - 2 and get 10% off
    • Buy 3 or above and get 15% off
    Feature & Benefits
    This wheel stud kit will convert your OE loose wheel studs to permanently attached to the hub. It can save you time and efforts in brake and wheel maintenance w/o having to remove/attach the studs individually one-by-one.
    • 10 ea M12x1.5 (or M12x1.25) to M12x1.5x50mm length wheel studs.
    • 10 ea M12x1.5 wheel nuts.
    • 2 packs (0.5ml) Loctite 242 blue thread locker.
    Qty/Priced per axle, order qty 2 for car set @discounted price.
    Wheel stud grade: 10.9
    1. Clean the hub surface.
    2. Apply loctite to the hub thread end.
    3. Torqued to 70-75 ft-lb using a calibrated torque wrench in a star pattern.
    4. Re-check torque after the first heat cycle or 200 miles of driving to ensure long-term clamping reliability.
    kit contents
    • M14x1.5 Wheel Studs Conversion Kit (10 per Pack) kit contents
      MSRP: $145.00
      Now: $137.75
    • EVO 8/9/10 M12x1.5 Wheel Stud M12x1.5, 14mm longer than stock (10 pc. - Axle Set)
      MSRP: $93.50
      Now: $88.83
    • EVO 8/9/10 M12x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set)
      MSRP: $79.20
      Now: $75.24
    • image_9146 SRT-4 M121x1.5 Wheel Stud for Stock Replacement (10 pc. - Axle Set)
      MSRP: $79.20
      Now: $75.24
    • M12x1.5 Cap Bolts - Fully or partially threaded (4 ea./Pack) M12x1.5 Cap Bolts - Fully or partially threaded (4 ea./Pack)
      MSRP: $55.00
      Now: $52.50
    • RB-CCB Disc (380x28mm) - Price per pair.
      MSRP: $4,620.00
      Now: $4,389.00
