    • RB CCB Rotor Kit (380x34/380x30) for Lexus GS/GSF/RCF Models Retrofit Upgrade Conversion to CCB, Front & Rear (P/N 2C27 & 2C36) Note: Priced for 2 front rotors Only - Add Rear Kit option for 4 corners.
    MSRP: $6,630.00
    Now: $6,300.00
    (You save $330.00 )
    LX-CRK-RCF
    Available from::
    Figs Engineering
    • The ccb rotor kit is specially designed for GS/GSF/RCF owners to seamlessly (direct mount) upgrade/convert the stock iron to the ccb rotors made with the latest gen. 4 ccb rotor technology.
    • Installation requires a pair of front RCF 6 pot or RB 6-pot calipers.
    • Select the rear rotor option for the car set (4-corners)
    Kit contents:
    • 2 ea front ccb rotors (380x34mm vs. 380x38mm RCF Track Edition ccb)
    • 1 set front ccb pads for street driving.
    • Rear ccb rotor kit - Optional
    Replacement discs:
    • Front: CR10
    • Rear: CR27
    • Front: PD1440-360 (If RCF calipers)
    • Front: PD1666-360 (If RB calipers)
    • Rear: PD968-360
    Available from: Figs Engineering
    • RB CCB Rotor Kit (380x34/380x30) for Lexus ISF Retrofit Upgrade Conversion to CCB, Front & Rear (P/N 2C41 & 2C36) or (2R48 & 2C36) Priced for 2 front rotors Only. TE front caliper
      MSRP: $6,800.00
      Now: $6,450.00
      MSRP: $10,500.00
      Now: $9,975.00
      MSRP: $9,400.00
      Now: $8,930.00
    • rotor kit front rotor
      RB-CCB Rotor Kit (380x34) for Ford Mustang GT550 2015+, V8 Perf., Mach 1 (2021+) Front Upgrade CCB Conversion from Stock Iron Rotors
      MSRP: $6,820.00
      Now: $6,479.00
    • RB-CCB Rotor Kit (390/360) for Lamborghini Huracan 2014+ (See Model Options) Front & Rear (P/N: 2C10 & 2R53) RB-CCB Rotor Kit (390/360) for Lamborghini Huracan 2014+ (See Model Options) Front & Rear (P/N: 2C10 & 2R53)
      Now: $12,350.00
