    • RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73)
  • Front 2R72
  • Rear 2R73
  • oe front
  • oe rear
  • RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73) RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73) RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73) Front 2R72 Rear 2R73 oe front oe rear
    MSRP: $12,000.00
    Now: $11,400.00
    (You save $600.00 )
    LOT-CRK-380.350
    • 2 ea Front ccb rotors (380x32mm vs. OE 370x32mm)
    • 1 set Caliper spacer kit for the front BBK
    • 2 ea Rear ccb rotors (Same as stock 350x32mm)
    • 1 car set ccb brake pads
    Feature and benefits:
    1. Converting/Upgrade to the same rotor sizes as Porsche 997.2 pccb.
    2. Direct bolt on installation.
    3. Retains the use of OE calipers.
    4. Dramatic unsprung weight reduction.
    5. Great value for iron rotors conversion upgrade.
    6. Rotors are made of continuous carbon fiber much more stronger than OE/Brembo ccb.
    7. Rotors are directional vanes for a more efficient cooling.
    8. Lower maintenance & replacement cost than OE/Brembo CCM rotors.
    • Front pad: PD8187-360
    • Rear pad: PD4345-360
    Replacement discs:
    • Front disc: CR50
    • Rear disc: CR51
    Application notes:
    This rotor kit is made for stock iron & pad upgrade conversion to ccb, due to the constraint of caliper pad sizes we do not recommended this setup for heavy tracking.
    OE Calipers:
    • Front: AP #CP7545
      • Piston dia: 31.8/41.3mm
      • Brake pad : 149x61x16.8mm
    • Rear: AP #CP6692
      • Piston dia : 31.8/38.1mm
      • Brake pad: 130x55x16.8mm
    Installation review:
    • RacingBrake Carbon Ceramic Rotor Install
    • 3,500-mile update after install & bedding
      MSRP: $10,500.00
      Now: $9,975.00
    • RB 2 pc Rotor Kit (380/350) for Lotus Emira Front & Rear (P/N 2737 & 2738) front rotor
      MSRP: $2,900.00
      Now: $2,755.00
      MSRP: $14,348.41
      Now: $13,630.00
      MSRP: $10,500.00
      Now: $9,975.00
    • RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80)
      MSRP: $12,150.00
      Now: $11,530.00
