Quick view 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view McLaren "U-clips" Hardware Kit for OE Brembo Front CCM Rotors (10ea.) MSRP: $26.20 Was: Now: $15.00 Add to Cart Compare Quick view McLaren Hardware - M6 Bolts & Nuts for OE Brembo CCM Rotors ( 1 set) MSRP: $2.50 Was: Now: $2.25 Choose Options Compare Quick view McLaren Hardware I-Block for OE Brembo CCM Rotors ( 1 ea) MSRP: $3.00 Was: Now: $2.85 Choose Options Compare Quick view McLaren Hardware Kit for OE Brembo CCM Rotors (eg. Corvette ZR1, Camaro Z28, Mclaren, Ferrari etc.) MSRP: $19.00 Was: Now: $17.90 Choose Options Compare Quick view McLaren Hardware Kit for OE Brembo Rear CCM Rotors w/Stainless Steel Hat/Drum brake (Price/set) - Click "Buy in bulk and save" for Quantity Discount MSRP: $26.20 Was: Now: $24.90 Add to Cart Compare Quick view RacingBrake Front and Rear Stainless Steel Brake Line Set for Nissan GT-R R35 09+ (OEM Caliper Fitment) MSRP: $379.50 Was: Now: $300.00 Add to Cart Compare Quick view RB Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair MSRP: $1,815.00 Was: Now: $1,724.25 Choose Options Compare Quick view 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) 2 - Light weight composite hats (OE Emergency/Parking brake compatible) 20 - M6 self-locking nuts 20 - I Block (IB-30) 20 - M6x1 bolts 20 - Springs Weight comparison: OE Stainless Steel Hat: RB Composite Hat (Aluminum hat w/iron liner): MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) These light weight composite hats are fully compatible with OE Emergency brake. OE Stainless Steel Hat: RB Composite Hat (Aluminum hat w/iron liner): MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view McLaren "U-clips" Hardware Kit for OE Brembo Front CCM Rotors (10ea.) Qty: 10 clips. These components are "taken-off" from brand new OE Brembo CCM rotor assembly - New and never used. MSRP: $26.20 Was: Now: $15.00 Add to Cart Compare Quick view McLaren Hardware - M6 Bolts & Nuts for OE Brembo CCM Rotors ( 1 set) Qty: 1 ea M6 bolt, 1 ea M6 nut These components are "take-off" from brand a brand new OE Brembo CCM rotor assembly - New and un-used. MSRP: $2.50 Was: Now: $2.25 Choose Options Compare Quick view McLaren Hardware I-Block for OE Brembo CCM Rotors ( 1 ea) Qty: 1 ea I-Block These components are "take-off" from brand a brand new OE Brembo CCM rotor assembly - New and un-used. MSRP: $3.00 Was: Now: $2.85 Choose Options Compare Quick view McLaren Hardware Kit for OE Brembo CCM Rotors (eg. Corvette ZR1, Camaro Z28, Mclaren, Ferrari etc.) These componets are removed from new OE Brembo CCM rotor assembly, brand new and never used. Each set of hardware kit includes: 1 - Stainless spring 1 - M6 bolt (Choose length from the option) 1 - M6 nut Other OE components such as I-Block... MSRP: $19.00 Was: Now: $17.90 Choose Options Compare Quick view McLaren Hardware Kit for OE Brembo Rear CCM Rotors w/Stainless Steel Hat/Drum brake (Price/set) - Click "Buy in bulk and save" for Quantity Discount Each set of hardware kit includes: 1 - I-Block 1 - Stainless spring 1 - M6 bolt 1 - M6 nut You would require 10 sets per rotor assembly. These componnets are "take-off" from brand new OE Brembo CCM rotor assembly, brand new and never used. MSRP: $26.20 Was: Now: $24.90 Add to Cart Compare Quick view RacingBrake Front and Rear Stainless Steel Brake Line Set for Nissan GT-R R35 09+ (OEM Caliper Fitment) This brake line kit was exclusively developed by RB and comes with all the necessary components for a complete installation for front and rear axles and replaces OE hard lines. These lines are built to RB specifications, meeting D.O.T. Certified. MSRP: $379.50 Was: Now: $300.00 Add to Cart Compare Quick view RB Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair The price includes all the components needed for assembling 2 front rotors (Discs GM P/N: 20981826 are not included). Brake pads are NOT included but can be added from option or purchased here: PD1291-360 (RB ST600) Installation Note: Installation of... MSRP: $1,815.00 Was: Now: $1,724.25 Choose Options Compare 1 2 Next 1 2 Next Compare Selected × OK
