    • RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCB Rotors - Price is for 2 Hats
  • RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCB Rotors - Price is for 2 Hats RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCB Rotors - Price is for 2 Hats
    MSRP: $1,850.00
    Now: $1,757.50
    (You save $92.50 )
    (1 review) Write a Review
    H060_H043-K
    • 2 ea light weight rotor hats - Drum parking brake compatible.
    • 20 set of assembly hardware.
    • 2 ea caliper spacers & longer bolts for optional oversized (390mm) rotors
    • 1 set ccb brake pads (optional)
    • If you choose 380x34mm rotor, the rear calipers modification is required (widen the pad/disc groove).
    • Dust shield trimming trimming is required to clear the disc mounting tabs.
    Features
    • RB rear hat is 100% compatible and retains OE emergency brake, unlike others that made the hat from machining the aluminum just to fit brake shoes but can't be used for emergency braking.
    Reference links for GM rotors:
    • Rear 380x34mm:
    • Rear 390x32mm:
    • 5
      installed on 2018
      Posted by TO on Oct 12th 2021
      I didn't want to play around with the oem caliper in the rear so went with this hat to install the 390x32 brembo ring. really happy with the result. one additional thing to note besides cutting a piece of the dust plate. for my 2018, the dust plate has bumps that come in contact with the back of the rotor ring screws. make sure to bend those sections back about 2mm sure you don't grind the screw heads and make noise.
    • RB Hat & Hardware kit for Nissan GTR Front Upgrade to CCB Rotors - Price is for 2 Hats RB Hat & Hardware kit for Nissan GTR Front Upgrade to CCB Rotors - Price is for 2 Hats
      MSRP: $1,600.00
      Now: $1,520.00
    • RB CCB Rotor Hat & Hardware kit for Ford GT350 Rear w/Drum brake - Price is for a Pair
      MSRP: $1,640.00
      Now: $1,560.00
    • RB  Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair RB  Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair
      MSRP: $1,815.00
      Now: $1,724.25
    • RB Rotor Hats for Aston Martin DBS11 (2017+) Rear CCB to Iron Rotor Conversion (Price is for 2 ea.)
      MSRP: $625.00
      Now: $594.00
    • RB Rotor Hats for Aston Martin DBS11 (2017+) Front CCB to Iron Rotor Conversion (Price is for 2 ea.)
      MSRP: $625.00
      Now: $594.00
