          • LANCER (08-16) EVO 10
          • LANCER (03+06) EVO 8-9
          • 911-SC(65-89) 930/912
          • EMIRA
    • RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCM Rotors - Price is for 2 Hats
          • EMIRA
  • RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCM Rotors - Price is for 2 Hats RB Hat & Hardware kit for Nissan GTR Rear Upgrade to CCM Rotors - Price is for 2 Hats
    MSRP: $1,690.00
    Now: $1,596.00
    (You save $94.00 )
    (1 review) Write a Review
    H043-K
    • 2 ea rotor hats (required rotors GM P/N: 20981826 are not included)
    • 2 set of assembly hardware (RB design IB30-K)
    • 2 ea caliper spacers for oversized rotors (If 390mm rotors are choosen)
    • 4 ea M12x1.5x80 caliper mounting bolts - 80mm is all it needs but you can re-use OE bolts if you wish.
    Brake pads are NOT included but can be added from option or purchased here:
    PD968-360 (RB ST600)
    Trimming dustshield is required.
    Illustration:
    RB rear hat is 100% compatible and retains OE emergency brake, unlike others that made the hat from machining the aluminum just to fit brake shoes but can't be used for emergency braking.
    • 5
      installed on 2018
      Posted by TO on Oct 12th 2021
      I didn't want to play around with the oem caliper in the rear so went with this hat to install the 390x32 brembo ring. really happy with the result. one additional thing to note besides cutting a piece of the dust plate. for my 2018, the dust plate has bumps that come in contact with the back of the rotor ring screws. make sure to bend those sections back about 2mm sure you don't grind the screw heads and make noise.
    • RB Rotor Hat & Hardware kit for Nissan GTR Rear Retrofitted to GM CCM Discs (380x34mm-Not Included) - Price is for  2 hats
      MSRP: $1,788.00
      Now: $1,699.00
    • RB  Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair RB  Hat & Hardware kit for Nissan GTR Front CCM Discs (390x32mm) are Not Included - Price is for Pair
      MSRP: $1,815.00
      Now: $1,724.25
    • RB Rotor Hat & Hardware kit for Ford GT350 (Front CCM Discs 394x36mm are Not Included) - Price is for Pair
      MSRP: $1,518.00
      Now: $1,442.10
    • 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit)
      MSRP: $1,936.00
      Now: $1,839.20
    • RB CCB Rotor Hat & Hardware kit for Ford GT350 Rear w/Drum brake - Price is for a Pair
      MSRP: $1,640.00
      Now: $1,560.00
