    • RB CCB Rotor Kit (390x34/380x30) for Nissan GTR-35 Iron to CCB Conversion Upgrade - 100% Bolt-On Installation w/o Modifications to Calipers or Dust Shields, Fits ZR1 Larger Pads (P/N: 2C30 & 2C31)
  • Front
  • Rear
  • front
  • rear
  • RB CCB Rotor Kit (390x34/380x30) for Nissan GTR-35 Iron to CCB Conversion Upgrade - 100% Bolt-On Installation w/o Modifications to Calipers or Dust Shields,  Fits ZR1 Larger Pads (P/N: 2C30 & 2C31) Front Rear front rear
    MSRP: $11,720.00
    Now: $11,150.00
    (You save $570.00 )
    GTR-CRK-390.380
    Features and benefits:
      1. Rotor kits are exclusively developed for upgrading from OE iron rotors with a 100% direct bolt on installation.
      2. Discs are made of long carbon fibers and are directional, so they are stronger and can run cooler than
        Brembo's chopped carbon fibers and straight vanes.
      3. Rotors will fit under OE calipers w/o requiring any caliper or dust shield modifications like other aftermarket kits made with Corvette ZR1 discs.
      4. Rotors (front & rear) are made with larger annulus to accommodate deeper pads (same as ZR1) that can help to run the brake cooler than OE size pads although also compatible with stock size pads.
      5. Rear rotor hats are made with iron sleeve insert and is 100% compatible with OE emergency brakes.
    • 2 ea front CCM rotors (390x34mm) - No caliper modification is required
    • 2 ea rear CCM rotors (380x30mm) - No dust shield trimming is required
    • 2 ea rear ccm rotors bbk (390x32mm) - Optional, no dust shield trimming is required
    • 1 set CCB RB ST600 brake pads (Oversized from GTR stock pads = ZR1 size)
    Weight Saving:
    • PD-ZR1-360
    **Pagid/Endless pads are subject to availability.
    • Front: CR18
    • Rear: CR27 (for stock size 380x30mm)
    • Rear: CR20 (for bbk 390x32mm)
    Rotor pricing references:
    Compared to Surface Transforms:
    https://surfacetransforms.com/nissan-gtr-brake-kits
    • RB CCB Rotor Kit (390x34/380x30) for Nissan Skyline R34 Upgrade to CCB  with GTR R35 Calipers - 100% Bolt-On Installation w/o Modifications; Fit ZR1 Pads (P/N: 2R78 & 2R79) Front wt
      MSRP: $13,680.00
      Now: $12,996.00
      Now: $12,400.00
      MSRP: $4,060.00
      Now: $3,860.00
    • SALE
      RB-CCB Rotor Kit (380/360) for Acura NSX 17-23 (GEN 2) Iron Rotors Conversion Upgrade; Fit OE Calipers w/o Modifications (P/N 2R33 & 2R34) front oe
      MSRP: $12,200.00
      Was: $11,600.00
      Now: $10,600.00
      MSRP: $10,500.00
      Now: $9,975.00
