    • RB 2pc "Lightweight" Rotor Kit (390x32/390x30) for Camaro Z28 CCB to Iron Rotor Conversion (P/N 2416 & 2382)
  • 2461 front lightweight
  • 2382 Rear
  • RB 2pc "Lightweight" Rotor Kit (390x32/390x30) for Camaro Z28 CCB to Iron Rotor Conversion (P/N 2416 & 2382) 2461 front lightweight 2382 Rear
    Now: $3,383.00
    (You save )
    GM_Z28-CCB-IRON-LW
    Installation notes:
    • 100% Bolt on installations
    • Rotor kit is custom made for Z28 ccb conversion to iron rotors
    • Extremely "lightweight" (22.5 lbs) front rotors can save 3 lbs per rotor over standard iron conversion (390x36mm @25.7 lbs)
    • If you are providing the pads yourself, the front pads must be trimmed to 70mm depth to fit the narrower annulus discs.
    • Rear rotor hats are 100% emergency drum brake compatible.
    • 2 ea front 2 pc rotors (390x32 vs. OE ccb 390x36mm) - 390mm is the actual pad contact dia. and can eliminate the rusty rings on rotor edges.
    • 2 ea rear 2 pc rotors (390x30 vs. OE ccb 390x32mm)
    • 1 car set brake pads (optional)
    • Front: PD1395A
    • Rear: PD1165
    Rotor replacement ring:
    • Front: D601-11
    • Rear: D601-09
    • RB 2pc Rotor Kit (390x36/390x30) for GM Camaro Z28 ccb to Iron Conversion (P/N 2355 & 2382) 2381 Front
      MSRP: $3,100.00
      Now: $2,945.00
    • Brembo calipers
      RB 2pc Rotor Kit w/Camaro Z28 ccb Stock Calipers Brake Package for ALL Gen 5 (2010-15) Camaro (P/N 2355 & 2382)
      MSRP: $8,336.90
      Now: $7,920.06
      MSRP: $14,348.41
      Now: $13,630.00
    • RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645)
      MSRP: $3,320.00
      Now: $3,155.00
    • RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73) RB-CCB Rotor Kit (380/350) for Lotus Emira - Iron Rotor to Carbon Ceramic Rotor Conversion Upgrade (P/N 2R72 & 2R73)
      MSRP: $12,000.00
      Now: $11,400.00
