    • RB 2pc Rotor Kit (390x36/390x30) for GM Camaro Z28 ccb to Iron Conversion (P/N 2355 & 2382)
  • 2381 Front
  • 2382 Rear
  • RB 2pc Rotor Kit (390x36/390x30) for GM Camaro Z28 ccb to Iron Conversion (P/N 2355 & 2382) 2381 Front 2382 Rear
    MSRP: $3,100.00
    Now: $2,945.00
    (You save $155.00 )
    GM_Z28-ccb-iron
    • 100% bolt on w/o any modifications.
    • Direct conversion from OE ccb to iron rotors
    • Rear rotor hats are 100% emergency drum brake compatible
    • 2 ea front 2 pc rotors (390x36 vs. OE ccb 394x36mm) - 390mm is the actual pad contact dia. and can eliminate the rusty rings on rotor edges.
    • 2 ea rear 2 pc rotors (390x30mm vs. OE ccb 390x32mm)
    • 1 car set brake pads (optional)
    • Front: PD1395
    • Rear: PD1165
    Rotor replacement ring:
    • Front: D602-01
    • Rear: D601-09
    • RB 2pc "Lightweight" Rotor Kit (390x32/390x30) for Camaro Z28 CCB to Iron Rotor Conversion (P/N 2416 & 2382) 2461 front lightweight
      Now: $3,383.00
    • Brembo calipers
      RB 2pc Rotor Kit w/Camaro Z28 ccb Stock Calipers Brake Package for ALL Gen 5 (2010-15) Camaro (P/N 2355 & 2382)
      MSRP: $8,336.90
      Now: $7,920.06
    • SALE
      RB-CCB Carbon Ceramic Rotor Kit (394/390) for Camaro Z28 Replacement Front & Rear (P/N: 2C38 & 2C83)
      Was: $12,500.00
      Now: $11,250.00
    • RB 2Pc Rotor kit (400x38/380x28) for M3/M4 F80 with Gold Calipers: CCB to Iron Conversion (P/N 2490 & 2524)
      MSRP: $3,430.00
      Now: $3,090.00
    • RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645)
      MSRP: $3,320.00
      Now: $3,155.00
