    • GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86)
  • Front OE wt 30 lbs
  • Front ccb wt 13.3 lbs
  • Rear oe wt 23.9 lbs
  • Rear CCB (w/OE hat) wt 17.9 lbs
  • Rear CCB (w/rb light wt hat) wt: 13.1 lbs
  • GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) Front OE wt 30 lbs Front ccb wt 13.3 lbs Rear oe wt 23.9 lbs Rear CCB (w/OE hat) wt 17.9 lbs Rear CCB (w/rb light wt hat) wt: 13.1 lbs
    MSRP: $15,600.00
    Now: $14,820.00
    (You save $780.00 )
    GM-CRP-394.390
    This kit includes the following:
    • 2 ea Front CCM rotors (394x36mm)
    • 2 ea Rear CCM rotors (390x32mm) - Light wt RB hats option available
    • 2 ea Rear 4 pot brand new calipers - Red color option available
    • 1 set street pads for CCB rotors
    • 1 car set of stainless braied brake line
    Disc material upgrade option to continuous/long carbon fiber (vs. OE chopped fibers) is available
    Option note:
    • Front 6 pot calipers - You can re-use your OE 6 pot (ZL1/1LE) calipers, or add to order if your models are not ZL1/1LE.
    • OE rear calipers are made for 365mm rotors so they are not compatible with this kit with 390mm rotors so Z28 rear calipers are included by default.
    • Brake caliper color - Front is red, rear is Silver w/Z28 logo, or red.
    This value kit is specially developed* by RB for G6 owners - An affordable conversion upgrade to a complete CCM brake system with a 100% bolt-on installation & compatibility with G5 Z28 on calipers, rotors, and pads.
    • Custom made front hats to fit G6 spindle.
    • Rearrangement of front calipers cross-over tubes for correct caliper orientation.
    • Hydro-test on all 4 calipers to ensure function properly without leakage.
    Weight (lbs) comparison table:
      Rotor size F/R (mm) Front Rear Total/side Total/car Saving/car Wt Ratio (%)
    OE Iron Rotors 394x36/365x28 29.8 23.9 53.7 107.4 - 100
    CCB Rotors (Rear Z28 hat) 394x36/390x32 13.3 17.9 31.2 62.4 45 58.1
    CCB Rotors (Rear RB hat) 394x36/390x32 13.3 13.1 26.4 52.8 54.6 49.2
    • RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K)
      MSRP: $16,800.00
      Now: $15,960.00
    • RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12)
      Now: $12,350.00
    • GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86)
      MSRP: $14,500.00
      Now: $13,800.00
    • RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K)
      MSRP: $16,500.00
      Now: $15,675.00
      MSRP: $8,122.40
      Now: $7,716.28
