    • RB-CCB Rotor Kit (400/380) for Corvette C8 Z06/Z07 CCB Replacement (PN 2R28 & 2R32)
  • Front
  • Front ccb rotor wt
  • Rear
  • Rear ccb rotor wt
  • front 6 pot caliper
  • front pad
  • rear 4 pot caliper
  • rear pad
  • RB-CCB Rotor Kit (400/380) for Corvette C8 Z06/Z07 CCB Replacement (PN 2R28 & 2R32) Front Front ccb rotor wt Rear Rear ccb rotor wt front 6 pot caliper front pad rear 4 pot caliper rear pad
    MSRP: $13,400.00
    Now: $12,730.00
    (You save $670.00 )
    GM-CRK-400.380
    Installation notes:
    • Rotor kits are designed and made for stock ccb upgrade replacement.
    • Discs are made of long carbon fibers vs. OE chopped fibers for durability and improved performance.
    • Brake pads are RB's ST600 compound for street and spirited driving. (Track pads on request)
    • This rotor kit can also be installed on E-Ray w/iron rotors as ccb conversion upgrade but the front 6 pot calipers must be replaced to GM#85617027 (Rear calipers are the same for iron and ccb).
    • 2 ea front ccb rotors (400x38mm vs. OE 398x38)
    • 2 ea rear ccb rotors (380x34mm=Same as OE)
    • 1 car set ccb brake pads (Optional)
    • Front: PD1395-360
    • Rear: PD2503-360
    References:
    Front Pads: $762.79 https://www.gmpartsdirect.com/oem-pa...-pads-86824349
    Rear Pads: $662.68 https://www.tascaparts.com/oem-parts...d-kit-87842603
    Front Rotors: $5,098 for pair https://www.tascaparts.com/oem-parts/gm-rotor-84735443
    Rear Rotors: $5,148 for pair https://www.gmpartsdirect.com/oem-pa...6822033?c=az0x
    Total: $11,671
    • RB-CCB Rotor Kit (394/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2C38 & 2R32) front rotor 394x36
      MSRP: $12,300.00
      Now: $11,700.00
    • RB-CCB Rotor Kit (370/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2R77 & 2R32) Rear
      MSRP: $11,200.00
      Now: $10,785.00
    • RB-CCB Rotor Kit (400/380) for BMW M3/M4 F80 CCB Rotor Replacement (PN 2R13 & 2C14)
      MSRP: $13,600.00
      Now: $12,920.00
    • [PD2503-360] Brake Pads for Corvette C8 Z06 w/Z07 Track Package CCB Rotors [PD2503-360] Brake Pads for Corvette C8 Z06 w/Z07 Track Package CCB Rotors
      MSRP: $415.00
      Now: $395.00
    • RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27) RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27)
      MSRP: $13,500.00
      Now: $12,825.00
