    • RB-CCB Rotor Kit (400/370) for Cadillac CT5-V Blackwing Upgrade Conversion From Stock Iron Rotors Fits OE Calipers & Spindles (P/N 2R69 & 2R70)
  • OE pads
  • RB-CCB Rotor Kit (400/370) for Cadillac CT5-V Blackwing Upgrade Conversion From Stock Iron Rotors Fits OE Calipers & Spindles (P/N 2R69 & 2R70) OE pads
    Now: $12,350.00
    (You save $650.00 )
    GM-CRK-400.370
    • 2 ea front CCB rotors (400x36mm vs. OE 398x36)
    • 2 ea rear CCB rotors (370x28mm vs. OE 374x28). 370mm fits better than 374mm (No rusty lip on rotor edge.)
    • 1 car set CCB brake pads (optional)
    Replacement pads:
    • Front: PD1395-360
    • Rear: PD592M-360
    Rotor weight comparison:
    Installation notes:
    • This rotor kit is made for a direct swap upgrade conversion (from stock iron to ccb rotors) for CT5 Blackwing that has an ePB (electronic parking brake) only. Other trims (non Blackwing) and models (CT4) will not fit.
    • Rotors are made for upgrade conversion directly from stock iron to ccb.
    • 100% bolt-on, no modifications required.
    Fearture & benefits:
    • Retain the use of OE calipers and spindles.
    • Save money and troubles in swaping calipers, spindle knuckle hub.
    • Huge unsprung wt saving.
    • Improve performance & durability.
    • Literally no brake dust.
      MSRP: $14,348.41
      Now: $13,630.00
    • Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370):  Front & Rear (P/N 2730 & 2731) Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370):  Front & Rear (P/N 2730 & 2731)
      MSRP: $3,010.00
      Now: $2,860.00
      Now: $12,400.00
    • RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12)
      Now: $12,350.00
      MSRP: $10,500.00
      Now: $9,975.00
