    • RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12)
  • front
  • Rear
  • RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) front Rear
    Now: $12,350.00
    (You save $650.00 )
    GM-CRK-394.360
    Our rear rotor are mode to 30mm thickness (vs. OE 28mm) for extra large volume and thermal capacity due to iron rotor conversion, which will still fit under OE calipers w/o any issue or concern as long as your pads are no thicker than OE (15mm).
    Rotors are specifically designed and built for a direct conversion upgrade from OE's iron rotors, retaining G6 ZL1/1LE and CTS-V 6 pot front and 4 pot rear calipers (not included) for a bolt-on installation.
    The rear rotors are fully compatible with OE emergncy/parking drum brake.
    Kit Includes:
    • 2 ea front CCB rotors (394x36mm)
    • 2 ea rear CCB rotors (360x30mm vs. OE 365x28) - 360mm fits better than OE 365mm, and can elliminate rusty lip like OE.
    • 1 car set CCB brake pads (Optional)
    ST600 characteristics is very comparable to Pagid RSC1 and OE Brembo.
    • Excellent modulation
    • Litterly no dust
    • No squeak
    • Highly durable
    Replacement pads:
    • Front: PD1395-360
    • Rear: PD592M-360
    Rotor weight comparison:
    ROTOR WT. COMPARISON (LBS) FRONT REAR TOTAL
    OE 27 23 50/SIDE
    RB 14 11 25/SIDE
    WT. SAVING 13 12 25/SIDE
    WT. SAVING     50/CAR
    Calipers rebuild: Camaro
    • GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86) GM/Brembo CCB Brake Kit (394/390) for Camaro G6 2016+ & Cadillac V3 Upgrade (P/N 2C85 & 2C86)
      MSRP: $15,600.00
      Now: $14,820.00
    • RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K)
      MSRP: $16,800.00
      Now: $15,960.00
      MSRP: $8,122.40
      Now: $7,716.28
    • RB 2pc Rotor Kit (390/365) for Camaro ZL1/1LE G6 2017+ & Cadillac V3 (16+) Front & Rear (P/N 2543 & 2140) Front
      MSRP: $3,010.00
      Now: $2,860.00
      MSRP: $10,500.00
      Now: $9,975.00
