    • RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper (P/N 2072 & 2073) - Disc Finish: Drills & Slots
  • RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper  (P/N 2072 & 2073) - Disc Finish: Drills & Slots RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper  (P/N 2072 & 2073) - Disc Finish: Drills & Slots RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper  (P/N 2072 & 2073) - Disc Finish: Drills & Slots RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper  (P/N 2072 & 2073) - Disc Finish: Drills & Slots RB 2 Pc Rotor Kit (355x32/340x26) for C6 Corvette Z06 w/PBR 6/4 Pot Caliper  (P/N 2072 & 2073) - Disc Finish: Drills & Slots
    MSRP: $2,700.00
    Was: $2,565.00
    Now: $2,209.50
    (You save $490.50 )
    GM-C6-Z06
    • Front: D402-01-351
    • Rear: D308-04-351
    • Front pads: PD1185F
    • Rear pads: PD1185R
    Installation Notes:
    Rear rotor installation requires trimming the lip of backing plate to avoid interference w/two piece rotor harware.
    It is requiried to remove the REAR pad springs which not only will this not affect the pad installation but eliminates the rattling noise.
    RB rear rotor hats are made with light weight aluminum sheel with iron sleeve insert for the rear emergeny brake - 100% compatible with OE rear brake.
    Reference reading about the rear two piece rotors with drum (emergency/parking) brake:
    https://www.jeeptrackhawk.org/threads/rear-two-piece-rotors-just-for-the-weight-saving.7498/#post-74965
    Front: PD1185F
    Rear: PD1185R
    • Replacement Rotor Ring (Drill+Slot) for RB 4 Pot Caliper Kits
      MSRP: $636.90
      Now: $605.06
    • Corvette 6/4 Pot Caliper Brake Kit (390/380) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) Front Kit
      MSRP: $8,200.00
      Now: $7,790.00
    • RB 6/4 Pot Caliper Kit (360x32/360x26) for C5/C6 Corvette 97-13 (P/N 2371-K & 2402-K) RB 6/4 Pot Caliper Kit (360x32/360x26) for C5/C6 Corvette 97-13 (P/N 2371-K & 2402-K)
      MSRP: $7,063.10
      Now: $6,709.95
    • Boots and Seals Kit - Corvette C6 Z06 Rear Caliper (Price is for 2 Calipers)
    • image_6781
      Rotor Rings (355x32) for Corvette C6 Z06 Front Includes Hardware (Price per pair)
      MSRP: $856.90
      Now: $814.06
