          • LANCER (08-16) EVO 10
          • LANCER (03+06) EVO 8-9
          • EMIRA
    • RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K)
          • EMIRA
  • RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K) RB 6/4 Pot Caliper BBK (400/390) for Ford Raptor 2009+ Front and 2012+ w/ Rear Drum Brake (P/N 2615-K & 2616-K)
    MSRP: $9,750.00
    Now: $8,977.50
    (You save $772.50 )
    (2 reviews) Write a Review
    FOR-IRP-400.390
    Replacement pads:
    • PD1668.PD968
    • Front: D601-03
    • Rear: D603-02
    • Front kit: 2615-K
    • Rear kit:  2616-K
    2 Reviews Hide Reviews Show Reviews
    • 5
      100k Mile Road Test - RB Raptor BBK
      Posted by Tony Ferrugia on Oct 23rd 2025
      Wanted to provide a follow-up and contribute some current long-term BBK field experience…. 100k Mile Racing Brake BBK Review I have a 2018 Gen2 with a cable parking brake. I fitted at about 30k miles a full Ft+Rear Racing Brake (RB) BBK on my 2018 Raptor (Massive Fr 400mm w/ 6pot calipers / R 390mm w/4pot calipers) under 20" Vorsteiner VR wheels). ROCK SOLID! Ran these for over 100k miles with absolutely NO issues (actually, 110kmiles on original pads and rotors, and even then the rear pads and rotors still had a lot more life left). I wish Ford built engines as bulletproof as these brakes! Provided needed stopping confidence, absolutely no brake fade, LONG noise-free wear, and better pedal feel (with full SS brake lines) vs. mushy OEM. Ran these brakes in a lot of different environments, including some off-road, up and down local mountain roads/switchbacks, towing a 7klb boat, and a lot of highway miles. If looking for a Raptor BBK, I would HIGHLY recommend RB… IMHO RB builds solid and proven kit (period).
    • 5
      Wow! Raptor BBK Review and Long-Term Road Test
      Posted by TJF on Dec 19th 2021
      I was an early adopter of RB on the Gen2 Raptor. Warren at RB worked with me through the entire process and made EVERYTHING right. Outstanding customer service and dedication to perfection... could not have asked for more. The F+R BBK is HUGE and looks amazing on my Raptor even with 20" Vorsteiner wheels and 35s. I selected this kit as it simply offered a very unique value proposition not available elsewhere. IMO RB was a much better option than Alcon or Baer (very heavy kits with lesser capabilities and rotor size options), a better price/performance option than Wilwood, MUCH better quality than some other heavily advertised and comparably priced brands, and a bargain compared to Brembo (that I would have stressed out over taking off-road). IMHO RB provides a comparable if not better build quality than most of the big-name brand BBK manufactures and is a clear price/performance leader for the Raptor. RB uniquely combines a VERY SMART and bulletproof design from caliper construction/finish, floating hats/roators, and the unique drilled/slotted rotor design along with exceptional performance and durability. I have run these brakes now for 40k miles... NO ISSUES and 110% satisfied. Some initial squeal under light braking (has now subsided), no rust, a bit more brake dust vs. stock but expected given more aggressive pads (but not bad), but most of all noticeable and GREATLY improved stopping power with shorter stops (have not officially measured but clearly noticeable) along with NO FADE whatsoever under hard braking or towing my 6,500 lb boat. I also replaced all 6 Raptor brake lines with SS, and went with a high temp racing fluid. Overall result was a much firmer and higher pedal. For my largely street driving (with tune) along with occasional off-road use this was perfect and greatly preferred over the soft (spongey) and deep stock pedal feel/set up. I could not be happier with my purchase, RB's support, and now proven long-term performance of RB and this product. 100% worth the investment!!!
    • RB 6/4 Pot Caliper BBK (410/400) for Tundra (07-21) Front & Rear w/Drum Brake (P/N 2264-K & 2711-K) - Fits 20"  Wheels Front kit
      MSRP: $8,415.00
      Now: $7,995.00
    • Car kit Front rotor wt
      MSRP: $9,328.00
      Now: $8,861.60
    • RB BBK 6/4 Pot Caliper (390/390) Brake Kit for Mercedes G63/65; GL (X164), ML (W164) (P/N 2222-K & 2426-K)
      MSRP: $8,426.00
      Now: $8,004.70
    • RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K) RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K)
      MSRP: $6,138.00
      Now: $5,831.10
    • RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K) RB BBK (420/390) for Corvette C8 Front & Rear (P/N 2670-K & 2646-K)
      MSRP: $10,512.00
      Now: $9,986.60
