    • RB 2pc Rotor Kit (380/380) for Ford Mustang Shelby GT350 2016+ Downsized from stock for Track Racing (delete rear drum brake) (P/N 2611 & 2612)
  • Front OEM
  • Rear oem
  • RB 2pc Rotor Kit (380/380) for Ford Mustang Shelby GT350 2016+ Downsized from stock for Track Racing (delete rear drum brake) (P/N 2611 & 2612) Front OEM Rear oem
    MSRP: $3,025.00
    Now: $2,873.75
    (You save $151.25 )
    FOR-IRK-380.380
    ROTOR WT. COMPARISON (LBS) per rotor FRONT REAR
    OE 30.3 19.1
    RB
    26.5 18.5
    • 2 ea front rotors (380x36 vs. OE 394x36mm)
    • 2 ea rear rotors (380x28 vs. OE 380x26mm)
    • 1 set brake pads (optional)
    This rotor kit is specially develped for track racing only:
    • Front rotor is downsized to 380mm to fit 19" wheels.
    • Rear rotor drum brake is deleted to reduce the weight.
    • Require to trim front OE caliper legs to fit 380mm rotors.
    Brake pads included in the kit is for street driving, for off street applications please click the link below for additional choices:
    Brake pad Selection Guide
    • Front: PD1395*
    • Rear: PD592
    *The pad spring hardware kit (below) is included in the kit "free of charge" for customers who purchased the complete car kit.
    Once they are installed to front caliper hold-down springs, you can use standard ZR1/Z28 brake pads in future front pad replacement w/o rattling (Same RB pad set supplied with this kit) which is cheaper and more easily available than stock GT350 pads.
    • Front: D602-04
    • Rear: 1503-11
    • RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description RB Caliper Kit (380/380) for Ford Mustang GT350 Track Racing. Rear rotors are not compatible with OE drum parking brake - See disclaimer under description
      MSRP: $7,920.00
      Now: $7,524.00
    • RB 2pc Rotor Kit (394x36/380x28) for Ford Mustang Shelby GT350 2016+ Stock Replacement Front & Rear (P/N 2568 & 2569) Front
      MSRP: $2,900.00
      Now: $2,755.00
    • RB-CCB System Kit (380/380) 6/4 Pot Calipers for Ford GT, Mustang GT350 (PN 2C69 & 2C17) - Fits 18" Wheels (vs. OE 19") for Low Cost Wheels/Tires - Custom built for Track Racing Only - Must Delete Rear Emergency Drum Brakes. RB-CCB System Kit (380/380) 6/4 Pot Calipers for Ford GT, Mustang GT350 (PN 2C69 & 2C17) - Fits 18" Wheels (vs. OE 19") for Low Cost Wheels/Tires - Custom built for Track Racing Only - Must Delete Rear Emergency Drum Brakes.
      MSRP: $16,000.00
      Now: $15,200.00
    • RB 2pc Rotor Kit (380/380) for Nissan GTR 09-11 Stock Replacement (P/N 2163 & 2184) Rear
      MSRP: $3,055.00
      Now: $2,750.00
    • RB 2Pc Rotor Kit - Ford Mustang Shelby GT500 2013-15 REAR
      MSRP: $1,223.20
      Now: $1,162.04
