    • RB 2 pc Rotor Kit (390/360) for Ford Mustang GT Dark Horse (2024+) Replacement Front & Rear (P/N 2727 & 2728)
  • front
  • Rear kit
  • front rotor
  • rear rotor
  • brake pads
  • front Rear kit RB 2 pc Rotor Kit (390/360) for Ford Mustang GT Dark Horse (2024+) Replacement Front & Rear (P/N 2727 & 2728) front rotor rear rotor brake pads
    MSRP: $2,885.00
    Now: $2,740.00
    (You save $145.00 )
    FOR-DH-IRK
    • 2 ea Front 2 pc rotors (390x36mm)
    • 2 ea Rear 2 pc rotors (360x28mm vs. OE 355x28)
    • 1 set rear caliper spacer kit for oversized rotors
    • 1 set brake pads (optional)
    Kits are designed and made to fit under OE 6 pot front and rear 4 pot calipers for a direct bolt-on installation.
    Front rotors are same size as OE, the rear is oversized to 360mm (vs. 355mm) which required a caliper spacer kit (included in the kit) for an easy installation.
    Weight comparison:
    Feature & Benefits:
    • Weight reduction.
    • Directional rotors for a more efficient cooling.
    • RB patented "Center-Mount" design improves the brake performance and durability.
    • Front: PD1395C
    • Rear: PD592
    • Front: D602-01
    • Rear: D502-09
    front
    • Rotor Kit Front
      RB-CCB Rotor kit (390/360) for Ford Mustang Dark Horse (2024+) Upgrade Conversion from Iron Rotors Front & Rear (P/N 2R11 & 2R68)
      MSRP: $12,000.00
      Now: $11,400.00
    • RB Brake Kit (390/390) for Ford Mustang 2015+ Front & Rear (P/N 2305 & 2306)
      MSRP: $9,958.30
      Now: $9,460.39
    • RB 2 pc Rotor Kit - Ford Mustang 2005-14 Rear RB 2 pc Rotor Kit - Ford Mustang 2005-14 Rear
      MSRP: $957.00
      Now: $909.15
    • RB 2 pc Rotor Kit (380/350) for Nissan Z Nismo 2024+ Stock Replacement Front & Rear (P/N 2163 & 2046) front oe wt
      MSRP: $2,800.00
      Now: $2,520.00
    • RB-CCB Replacement Rotors (390/380) for McLaren 720S, 600LT, 2020+ GT Front & Rear (P/N 2R36 & 2R37) front dim
      MSRP: $15,120.00
      Now: $14,360.00
